Problem Loading UDF
Old   May 1, 2013, 12:37
Default Problem Loading UDF
vagaikwa is on a distinguished road
I purchased a student license version Ansys 14.5. I am running Fluent 14.5 in it. I am trying to load a UDF in it and when I click on Build, it says that fl6326s.exe is missing from your computer. Error code: 126
What can be done about it?
vagaikwa is offline   Reply With Quote
Old   May 2, 2013, 01:45
Paritosh Vasava
vasava will become famous soon enough
I think you have some missing dll files. What operating system are you using?
vasava is offline   Reply With Quote
Old   May 2, 2013, 02:21
Windows 7..
Old   May 2, 2013, 03:19
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I don't know the answer but maybe a problem related to system variables?
Doesn't fl6326s.exe refer to Fluent version 6.3.26?But you have ansys 14.5...Check system variables, the problem might be there..
Daniele
ghost82 is offline   Reply With Quote
Old   May 2, 2013, 05:43
Paritosh Vasava
Before installation did you check if all the pre-requisites are installed? In the very first step when you begin the installation procedure, there is an option to check and install the pre-requisites.
Old   May 2, 2013, 05:47
ghost82's Avatar
Rick
Originally Posted by vasava View Post
I think fl6326s.exe has something to do with serial processing and nothing to do with the version of the Ansys.
Yes, it is the solver process, but it refers to version 6.3.26 and this is strange in my opinion.
Old   May 2, 2013, 07:00
Paritosh Vasava
Yes!! You are right. I will edit my comment before someone takes it seriously.
Old   May 2, 2013, 07:03
Paritosh Vasava
@vagaikwa: Did you install Visual Studio for UDF compilation? Also can you share your UDF here? Lets see if that part is ok.
Old   May 2, 2013, 11:43
Thanks for your replies guys..I have fluent 6.3.26 installed already..I guess I need to uninstall it..I moved my udf and my cas/dat file to a different location..And then I run the the fluent14.5 through SDK command prompt. But now it is giving me this error..
The UDF library you are trying to load (libudf) is not compiled for 2ddp on the current platform (win64)
Old   May 2, 2013, 11:45
#include "udf.h"
#include "stdio.h"
#include "math.h"
#define lambda 0.11
#define erbc 0.45
#define mup 0.001
DEFINE_PROPERTY(cumul_viscosity,c,t)
real mu_blood,gamma,a,n,m;
double s1, ko,shear_rate;
gamma = C_STRAIN_RATE_MAG(c,t);
/*Calculating Dimensionless shear rate*/
shear_rate = 1+pow((lambda*gamma),2);
s1 = (double) log ((double) shear_rate);
ko = ((double) log ((double) s1))/((double) s1);
if(shear_rate>=1.5)
n = 0.8092*(pow(erbc,3))-0.8246*(pow(erbc,2))-0.3503*erbc+1;
m=122.28*(pow(erbc,3))-51.213*(pow(erbc,2))+16.305*erbc+1;
/*Low shear rate*/
else
n = ko*(-0.8913*(pow(erbc,3))+2.0679*(pow(erbc,2))-1.7814*erbc)+1;
m=70.782*(pow(erbc,3))-22.454*(pow(erbc,2))+9.7193*erbc+1;
a = 0.5*(n-1);
/*Multiplying dimensionless shear rate by viscosity of plasma 0.001*/
mu_blood = mup*m*(pow(shear_rate,a));
return mu_blood;
Here is my udf
Old   May 3, 2013, 01:38
Paritosh Vasava
This error is because you have not setup the visual studio properly. I think you must read threads related to this issue and try to fix this.
Old   May 3, 2013, 13:44
ghost82's Avatar
Rick
...and you have to recompile your udf with the system you are using; first delete the libudf folder.
Daniele
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
Compiling / Loading UDF Martijn FLUENT 1 December 16, 2008 19:06
I have problem of UDF with turbulent premx source. Z FLUENT 0 February 16, 2005 03:34
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
