2D Pitching Airfoil
Old   May 6, 2013, 00:51
Default 2D Pitching Airfoil
samrat himvanth nanduri
samcfd is on a distinguished road
Dear all,
I'm using a UDF for pitching airfoil . The function i'm using is
omega[2] = 0.5 * pitchampl * (1-cos(w*time));
pitchampl = 25 * pi/180;
w = 2 * pi * 0.15;
when i use this function the airfoil is rotating 360 deg. i dont understand y..
but when i use omega[2] = 0.5 * pitchampl * sin(w*time); its pitching perfectly...
Could some1 pls tell me y this is happening.
thanks in advance,
regards,
sam
samcfd is offline   Reply With Quote
Old   May 6, 2013, 00:56
blackmask will become famous soon enough
Note that omega is angular speed rather than the angle of attack. You angular speed is always non-negative so that your airfoil is always pitch in the same direction. You need something like
d 0.5 * pitchampl * (1-cos(w*time))
d time
which leads to
omega[2] = w*0.5 * pitchampl * sin(w*time);
blackmask is offline   Reply With Quote
Old   May 6, 2013, 01:13
d time
which leads to
Dear Blackmask,
Thanks for your reply. I really didnt get wat u were saying. I want the airfoil to pitch using
omega[2] = 0.5 * pitchampl * (1-cos(w*time));.
what changes do i make..
thanks in advance,
regards,
sam.
Old   May 6, 2013, 01:52
I assume that you can tell the difference between pitch angle, say beta, and angular velocity, say omega. And you should know they are related by
omega[2] = d (beta) / dt (#)
While
beta(t) = 0.5 * pitchampl * (1-cos(w*time))
is the pitch angle in the above equation (#) (so that beta is in the range [0, pitchamp]), what you need to specify in the UDF is the angular velocity. That is what I tried to tell you in the last post.
Old   May 31, 2013, 01:37
Dear Blackmask,
How u keeping?? Hope all s gud.. I need a quick favor. Could u pls help me out on how to write a UDF for Rotating grid. Example: I have to circles one inside the otr n i need to rotate the inner circle at a particular RPM. mostly for turbine applications. could u help me..
thanks in advance...
Old   May 31, 2013, 02:56
Thanks, I am OK.
The sliding mesh is sufficient for your purpose. Use
DEFINE_TRANSIENT_PROFILE
for time varying rpm. Otherwise you do not need UDF at all.
Old   May 31, 2013, 03:00
Thanks for your reply.. but wen i use sliding mesh the grid does not rotate at all..i cant see rotation in animation also...
Old   February 3, 2014, 14:25
Rakesh
rsarma is on a distinguished road
Dear Blackmask,
This is in continuation of the earlier message that I sent you. I tried adjusting sin by cos. But the problem still persists. Could you put forward any other suggestion. Here is my problem.
I am dealing with a pitching airfoil problem. I am using dynamic mesh with a udf.
My airfoil is pitching fine, but I see that there is some problem with the axis. It is pitching about the Z-axis. But it should have both positive and negative angles of attack. However my airfoil is either pitching above or below the zero angle of attack line. Could you kindly help me out?
Thanks.
rsarma is offline   Reply With Quote
Old   February 22, 2014, 04:54
Musa
fkanyako is on a distinguished road
Originally Posted by rsarma View Post
Dear Blackmask,
Thanks.
Hi
I am having the same problem, have you manage to solve it ? please share the solution with me.. Thanks
fkanyako is offline   Reply With Quote
Old   February 22, 2014, 08:26
Rakesh
Dear Fkanyako,
Yeah it is solved now. I replaced sin by cos and it actually worked.
Old   February 25, 2014, 05:35
Musa
How did you determine your time step size ?
I normally cal. this way
omega = 2*pi *frequency
and t = 1/freq.
Dt = t/300 or 400 or 500 it depends on how many time steps per circle I want. If this approach is wrong then please tell how to do it.
Thanks
Old   February 25, 2014, 06:08
Rakesh
Well, your approach is correct. It all depends on the number of points you want in each cycle. I typically was interested in about 20 points in a cycle for my application. So you can accordingly adjust that.
Good Luck!
Old   January 10, 2015, 13:14
airbus is on a distinguished road
Hello everybody
I'm working on incompressible unsteady force measurement of two-dimensional naca0012 under pitch-up, hold and pitch-down motion at a constant velocity about 50 m/s
Recently I examined the model in static mode at various AOA in Fluent , but i've a problem for write a correct""UDF"" for Dynamic mode test that airfoil at defined AOA by specified HOLD time (h : holding factor) set in during motion as pitch up, HOLD , and return for different cases by different amplitude angular pitching rates
I'll so grateful to help me for doing this part
Thank you
airbus is offline   Reply With Quote
Pitching Airfoil in FLUENT salihovic FLUENT 2 October 24, 2013 13:58
Airfoil pitching problem montag dp FLUENT 12 June 25, 2012 06:25
Airfoil Pitching sheth Fluent UDF and Scheme Programming 2 March 11, 2012 02:17
[ICEM] Dynamic mesh for a pitching airfoil bahram.raeisi ANSYS Meshing & Geometry 1 March 2, 2012 10:41
How to realize pitching airfoil with drooping nose calcualtion? zeitistgeld CFX 1 July 27, 2010 07:17
