UDF for time-dependent flow
Old   May 28, 2013, 08:35
Default UDF for time-dependent flow
soodabe
borhan_sd@yahoo.com is on a distinguished road
Hi all ,I’m new in fluent and particularly UDF, I want to model a system that a gas is inlet and it flows for 3s and doesn’t flow for 3s alternatively and continuously. In fact it’s our respiration flow and the model is a respiratory mask.
How should I write UDF file? Probably CURRENT_TIMESTEP Macro should be used, Is it right?
Would you tell me please how should I write the UDF? This is very important for me.
Thank you very very much in advance.
borhan_sd@yahoo.com is offline   Reply With Quote
Old   May 29, 2013, 04:50
blackmask will become famous soon enough
Something looks like
#include "udf.h"
DEFINE_PROFILE(vel_in, thread, i)  {
    real y;
    face_t f;
    real t = CURRENT_TIME;
    int off = (int) (t/0.03+0.5) %2;
    begin_f_loop(f,thread)
        if (!off)
            F_PROFILE(f,thread,i) = 1.0;
    end_f_loop(f,thread)
Modify it to suit your needs.
blackmask is offline   Reply With Quote
Old   May 30, 2013, 02:59
soodabe
thank you very much for your quick reply
regards
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
Density UDF for supersonic flow David Christopher Fluent UDF and Scheme Programming 0 April 18, 2013 05:48
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
UDF for multiphase flow ROOZBEH FLUENT 3 April 7, 2004 17:54
