Global Reductions
Old   August 27, 2013, 17:02
Default Global Reductions
Andrew Kokemoor
Kokemoor is on a distinguished road
I'm trying to use a global reduction, specifically PRF_GRSUM1, in my parallel interpreted UDF. Seems that it should be pretty straightforward, but I'm getting errors.
Error: ... line 30: MPT_gdsum1: no function prototype
I went digging around to find how it's defined, and found that prf.h has
#define PRF_GRSUM1 MPT_GDSUM1
, but no prototype. reductions.h has a prototype, but if I include it, I get the following:
Error: C:\\PROGRA~1\\ANSYSI~1\\v145\\fluent\\fluent14.5.0/multiport/src/reductions.h: line 393: MPT_check has already been defined in the current frame
Does anyone know anything about how this is all put together? Why isn't this covered by including udf.h?
Kokemoor is offline   Reply With Quote
Old   November 27, 2014, 09:16
Rudi
rudofly is on a distinguished road
Dear Andrew,
I am facing the same problem interpreting in Fluent's parallel mode. I have tried to avoid multiple definition by preprocessor statements in the usual pattern. But it didn't prevent reinterpreting of the files.
#ifndef SOMETHING
#include <udf.h>
#include <sg_ls.h>
#define SOMETHING
#endif
Have you been able to solve your problem?
Best regards,
Rudi
rudofly is offline   Reply With Quote
Old   December 1, 2014, 10:17
Andrew Kokemoor
In the end, I ended up compiling my UDF. Not sure if that's what fixed it, or if I did something else, but my final UDF #includes udf.h and nothing else.
Old   December 2, 2014, 08:34
Rudi
Upon your hint, I have removed sg_ls.h from includes. Instead I 'exported', which is to say I copied, the definition I needed into my file.
Interpreting it went through without redefinition error :-) Thanks!
Rudi
Old   September 16, 2019, 04:43
Default I met the same problem
WANG LU
smilingwl is on a distinguished road
I have found the reductions.h,but,I can't find the define of the MPT_GDSUM1,could you tell me the define of the MPT_GDSUM1
smilingwl is offline   Reply With Quote
Old   September 23, 2019, 05:23
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
use PRF_GRSUM1 for global redution
read ansys fluent customization manual for more details
best regards
AlexanderZ is offline   Reply With Quote
Old   September 25, 2019, 03:55
WANG LU
Dear AlexanderZ:
Thank you so much for your answer.
The advice you suggested I have tried, but it still goes wrong.
It shows MPT_gdsum1: no function prototype.
I have no idea how to adjust my UDF.
My code as follow, could you tell me what is going wrong?
#include "udf.h"
#include "prf.h"
DEFINE_EXECUTE_AT_END(centroid)
#if !RP_HOST
real wcx = 0.0;
real wcy = 0.0;
real va_liq = 0.0;
real cx, cy;
real x, y;
cell_t c;
real z[ND_ND];
Domain *subdomain= Get_Domain(3);
Thread *t;
#endif
#if !RP_NODE
FILE *fout1;
FILE *fout2;
#endif
#if !RP_HOST
thread_loop_c(t,subdomain)
begin_c_loop(c, t)
if(0.5<=C_VOF(c,t)&&C_VOF(c,t)<=1.0)
va_liq = va_liq + C_VOLUME(c,t);
C_CENTROID(z,c,t);
wcx = wcx + z[0]*C_VOLUME(c,t);
wcy = wcy + z[1]*C_VOLUME(c,t);
end_c_loop(c, t)
va_liq = PRF_GDSUM1(va_liq);
wcx = PRF_GDSUM1(wcx);
wcy = PRF_GDSUM1(wcy);
cx = wcx/va_liq;
cy = wcy/va_liq;
#endif
#if !RP_NODE
fout1 = fopen("X-centroid of liquid.txt","a");
fout2 = fopen("Y-centroid of liquid.txt","a");
#endif
node_to_host_real_2(cx, cy);
#if RP_HOST
fprintf(fout1,"%g,%g\n",CURRENT_TIME,cx);
fprintf(fout2,"%g,%g\n",CURRENT_TIME,cy);
#endif
#if !RP_NODE
fclose(fout1);
fclose(fout2);
Message("\n X-centroid of liquid = %g\n", cx);
Message("\n Y-centroid of liquid = %g\n", cy);
#endif
Thanks a lot.
Best regards.
Wang Lu
Old   September 25, 2019, 05:09
Alexander
#include "udf.h"
#include "prf.h"
real wcx = 0.0;
real wcy = 0.0;
real va_liq = 0.0;
real cx, cy;
real x, y;
cell_t c;
real z[ND_ND];
Thread *t;
#if !RP_NODE
FILE *fout1;
FILE *fout2;
#endif
#if !RP_HOST
begin_c_loop(c, t)
C_CENTROID(z,c,t);
end_c_loop(c, t)
cx = wcx/va_liq;
cy = wcy/va_liq;
#endif
#if !RP_NODE
#endif
#if RP_HOST
#endif
#if !RP_NODE
fclose(fout1);
fclose(fout2);
#endif
this code is complied with no error
best regards
Old   September 25, 2019, 07:23
WANG LU
Dear AlexanderZ:
Thank you for your answer. But when I interpret it, it gets wrong,I don't know what is up. Can you try to interpret my code in your fluent?I know it's rude to ask that. But I really want to know what is going up,my system or something else.
Thank you a lot.
Best regards.
Wang Lu.
Old   September 25, 2019, 21:35
Alexander
As I've told, compile this code and try to run it
best regards
Old   September 25, 2019, 22:42
WANG LU
Thanks a lot for your answer.
Best regards!
Wang Lu
Old   September 26, 2019, 03:54
WANG LU
Dear AlexanderZ:
I still can not compile my code.
When I compile my code ,it shows error like "The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64)".
Do you know what's wrong?
Beat regards!
Wang Lu
Old   September 26, 2019, 20:11
Alexander
this code, which I've attached, is compiled well
to compile code:
run fluent from visual studio command prompt (or SDK command prompt) -> user defined -> functions -> compiled -> BUILD
best regards
Old   September 27, 2019, 08:48
WANG LU
Dear AlexanderZ:
Thank you for your answer.I just did what you have told,but it still shows wrong.I made a video which recorded what I did and upload on the website as follow,so that you can know what I have done.
https://user.qzone.qq.com/651668162/main
Best regards!
Wang Lu
Old   September 27, 2019, 09:17
WANG LU
Dear AlexanderZ
I need to change the website to
Best regards!
Wang Lu
Old   September 28, 2019, 09:04
WANG LU
Dear AlexanderZ
Today,I try to compile my UDF,and run my Fluent. The UDF can be compiled,but it can't output the file, and the case interrupt.I think my UDF still have the coding error. Could you help me correct my UDF.
Blessing to you.
WangLu
Old   September 28, 2019, 09:32
pakk will become famous soon enough
Show what is written on your screen after you click "build". (not what happens after you click "load").
It might be in your video, but I am not going to watch a video.
pakk is offline   Reply With Quote
Old   September 28, 2019, 21:00
WANG LU
Dear pakk:
Thank you for your answer.It shows as follow:
Copied F:\wldaoliuban\case\25_4/F:\wldaoliuban\case\25_4\centroid_parallel_wl.c to libudf\src
Copied F:\wldaoliuban\case\25_4/F:\wldaoliuban\case\25_4\udf.h to libudf\src
Creating user_nt.udf file for 3ddp_host ...
(system "copy "D:\ANSYS\ANSYS Inc\v180\fluent"\fluent18.0.0\src\udf\makefile_nt. udf "libudf\win64\3ddp_host\makefile" ")
已复制 1 个文件。
(chdir "libudf")(chdir "win64\3ddp_host")# Generating ud_io1.h
# Generating udf_names.c because of makefile centroid_parallel_wl.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj centroid_parallel_wl.obj
Microsoft (R) Incremental Linker Version 12.00.21005.1
Copyright (C) Microsoft Corporation. All rights reserved.
正在创建库 libudf.lib 和对象 libudf.exp
Creating user_nt.udf file for 3ddp_node ...
(system "copy "D:\ANSYS\ANSYS Inc\v180\fluent"\fluent18.0.0\src\udf\makefile_nt. udf "libudf\win64\3ddp_node\makefile" ")
已复制 1 个文件。
(chdir "libudf")(chdir "win64\3ddp_node")# Generating ud_io1.h
udf_names.c
Done.
Best regards!
WangLu
Old   September 29, 2019, 21:44
Alexander
try to run this code
#include "udf.h"
#include "prf.h"
real wcx = 0.0;
real wcy = 0.0;
real va_liq = 0.0;
real cx, cy;
real x, y;
cell_t c;
real z[ND_ND];
Thread *t;
#if !RP_NODE
FILE *fout1;
FILE *fout2;
#endif
#if !RP_HOST
begin_c_loop(c, t)
C_CENTROID(z,c,t);
end_c_loop(c, t)
va_liq = PRF_GISUM1(va_liq);
wcx = PRF_GISUM1(wcx);
wcy = PRF_GISUM1(wcy);
cx = wcx/va_liq;
cy = wcy/va_liq;
Message0("cx cy where calculated successfully\n");
#endif
#if !RP_NODE
Message0("store files where opened \n");
#endif
#if RP_HOST
Message0("data stored successfully \n\n");
#endif
#if !RP_NODE
fclose(fout1);
fclose(fout2);
Message0("\n X-centroid of liquid = %g\n", cx);
Message0("\n Y-centroid of liquid = %g\n", cy);
#endif
if there still be problems -> show you console output
best regards
Old   October 2, 2019, 23:43
WANG LU
Dear AlexanderZ:
Thank you so much to help me correct my UDF. I am so happy to see my case run well with the UDF. But it still has a little error. The result in the text the case output is different with the result in the serial veision.
It shows :"0.01,-1.#IND"
In the serial version, it shows:"0.01,0.053456"
Thank you again.
Best Regards!
Wanglu
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
