Error: The UDF library you are trying to load is not compiled for 3ddp on the current |
November 21, 2013, 06:45 |
Josiah Sng
Hi, I am currently doing an analysis on UV water treatment. I want to calculate the UV dose travelling through a UV chamber.
I downloaded a UDF from this website: http://www.sandia.gov/cfd-water/uvdi...tion.htm#tools and tried to load it in Ansys fluent using the instructions provided. I tried using both the UDF for parallel and serial, but it always comes up with an error. I got this error message: Opening library "D:\University\FYP\Ansys tutorials\Current coding project\try_ok_files\dp0\FLU\Fluent\D:\University\ FYP\Ansys tutorials\Current coding project\try_ok_files\dp0\FLU\Fluent\libudf"... Error: The UDF library you are trying to load (D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\libudf) is not compiled for 3ddp on the current platform (win64). The system cannot find the path specified. D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\libudf\win64\3ddp\libud f.dll Error Object: #f Is it possible that someone can give me suggestions on what I am doing wrongly? I am currently using ansys Fluent 14.5 on windows 8 64bit. I read on the forums that I need an SDK 7.1 to do the compilation. Is that related to my current problem? Where can I download it? I just installed Microsoft .NET Framework 4.5 SDK is it the same as SDK 7.1? |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
Compiled library vs. inInclude Files, DSMC solver crashes after run | GPesch | OpenFOAM Programming & Development | 8 | April 18, 2013 07:17 |
calling result of a UDF into current time step | Komon | Fluent UDF and Scheme Programming | 1 | April 1, 2012 19:53 |
cannot load UDF library | jayilosa | Fluent UDF and Scheme Programming | 3 | November 16, 2011 12:44 |
building compiled udf s in windows | sourav | FLUENT | 8 | August 18, 2005 01:46 |
