using C_VOF
Old   November 25, 2013, 11:39
Default using C_VOF
anonymous
MichaelVS is on a distinguished road
Dear Colleagues,
I need your help in using C_VOF macro.
In my project I need to capture the interface between two fluids (C_VOF=0.5) and assign to the cells on the interface the values I would like to (for example temperature).
The problem is that I cannot select the cells with C_VOF = 0.5 . The udf works if I select cells with C_VOF=1 or 0, but not with the interface.
How could I make it?
Here is my udf
#include "udf.h"
#include "sg_mphase.h"
DEFINE_ADJUST(scan3,d)
Thread *t;
Thread **pt;
cell_t c;
int zone_ID=2;
Thread *mixture_thread = Lookup_Thread(d,zone_ID);
pt = THREAD_SUB_THREADS(mixture_thread);
thread_loop_c(t,d)
begin_c_loop(c,t)
if (C_VOF(c,pt[1])==0.5) /* pt0 - air, pt1 - ls */
C_T(c,pt[1])=1500;
end_c_loop(c,t)
MichaelVS is offline   Reply With Quote
Old   November 26, 2013, 02:12
Max
coglione is on a distinguished road
You are searching for cells with vof == 0.5 exactly. Maybe there is no cell which matches this strict requirement but certainly there will be some with 0.49<C_VOF<0.51.
Cheers
coglione is offline   Reply With Quote
Old   November 26, 2013, 03:54
anonymous
Thank you very much for your reply!
No, this cells don't exist too.
However, it works if I specify the range of C_VOF from 0.000001 to 0.999999 . But also not always as well... it somehow depends on time-step size and number of iterations per step.
For example if I set up time-step 0,05 sec and 5 iterations per step then it works, but if i set up time-step 0.05 and 20 iterations it doesn't.
... and this doesn't make any sense to me. Any ideas?
Cheers
Old   July 20, 2020, 15:30
Sagar Nikam
nikamsagar45 is on a distinguished road
Did you manage to solve the problem?
I am facing a similar problem. If you solved the problem can you please guide me?
Thank you
nikamsagar45 is offline   Reply With Quote
