trying to write a UDF for rigid body motion
Old   December 2, 2014, 17:59
Exclamation trying to write a UDF for rigid body motion
niteshrajput is on a distinguished road
I am trying to write a UDF for rigid body motion.
The airfoil pitches from -0.03 to 15.54 degrees. It is a simple ramp case.
The motion of the airfoil is as shown in the figure.
Please help how do I define the motion of the grid with rigid body motion.
I have equation of motion, will that be used anywhere in the UDF. Please help.
niteshrajput is offline   Reply With Quote
Old   December 10, 2014, 03:45
koray is on a distinguished road
Hey,
You can simply generate points for omega with respect to time by using your equation (in MS Excel for instance). Then, you can transfer these points into a text file in a Fluent profile file (*.prof) format. After, hooking the profile onto the rigid zone, you can simulate the motion with the appropriate dynamic mesh settings.
And if you want a UDF to calculate each position at each timestep by using your equation, then you can use DEFINE_CG_MOTION macro to introduce your the angular velocity as a function of time. Please, check Ansys Help. There you can find UDFs very similar to your case.
Hope, this helps.
Cheers,
Koray
koray is offline   Reply With Quote
Old   December 15, 2014, 13:34
Srinivasa Reddy
srireddyn is on a distinguished road
Hi koray
Is it possible to avoid UDF for dynamic mesh with some table data to define the motion of the boundary?
srireddyn is offline   Reply With Quote
Old   December 15, 2014, 14:46
Originally Posted by srireddyn View Post
Hi koray
Is it possible to avoid UDF for dynamic mesh with some table data to define the motion of the boundar?
Hi there,
Just check ansys help and look for profile under fluent user guide. It's very straightforward.
Cheers,
Koray
Old   December 17, 2014, 00:29
Srinivasa Reddy
Thanks koray!
I have checked. I should try it out.
CG Motion UDF Problem leoarmas Fluent UDF and Scheme Programming 17 February 14, 2023 08:59
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
UDF to control motion NOT about CG LenDawg0220 Fluent UDF and Scheme Programming 0 July 28, 2012 12:54
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 03:06
UDF to write interp files Karl FLUENT 6 February 7, 2002 12:10
