DEFINE_MASS_TRANSFER Units
Old   January 27, 2014, 17:20
Question DEFINE_MASS_TRANSFER Units
Quinos is on a distinguished road
I am trying to write a UDF to describe mass transfer between phases. One website (http://aerojet.engr.ucdavis.edu/flue...udf/node57.htm) says that DEFINE_MASS_TRANSFER returns units in kg/m^3. However, when describing the example code, it also says that, "The following UDF, named liq_gas_source, specifies a simple mass transfer coefficient based on saturation temperature."
I thought that mass transfer coefficients were in the units of m/s, not kg/m^3. What exactly is DEFINE_MASS_TRANSFER supposed to return?
Thank you for any help.
Quinos is offline   Reply With Quote
Old   January 28, 2014, 03:53
pakk will become famous soon enough
To add a third option: my version of the help says:
Your UDF will need to return the real value of the mass transfer to the solver in the units of kg/m^3/s.
I never used it, so I don't know what is true.
pakk is offline   Reply With Quote
Thermophysical Property Units johanz OpenFOAM Pre-Processing 2 December 16, 2018 10:08
Writing XY plots with Non-SI units Akhundzada91 FLUENT 0 August 27, 2013 11:11
How do I change the units? jstaker7 Autodesk Simulation CFD 1 January 7, 2013 18:42
units in OpenFOAM megacrout OpenFOAM 4 July 19, 2011 08:04
Mass transfer units in fluent nite_surfer FLUENT 0 July 12, 2007 12:51
