Errors in defining a source term
Like Tree1Likes
  • 1 Post By pakk
Old   February 10, 2014, 14:02
Default Errors in defining a source term
Michigan
lxlxlxt is an unknown quantity at this point
Hi all,
I'm having some trouble with a source term. I used the species transport and reaction model but since the model contains polymers, I don't know the accurate standard state enthalpy. So I set the standard state enthalpy to 0 and specified a reaction source term as follows:
/*UDF for energy source term of the reactions*/
#include "udf.h"
#define Aw 1385.;
#define Ew 3.266e+4;
#define AOH 1.7348;
#define EOH 4.04e+4;
#define Rg 8.314;
#define cw0 776.74;
#define coh0 3032.56;
#define cn0 4581.40;
#define delhyd 7.075e+4;
#define delwat 8.6e+4;
DEFINE_SOURCE(energy_source1,c,t,dS,eqn)
int j;
int k;
real convoh;
real convw;
real q;
real n;
real source;
Material *m = THREAD_MATERIAL(t);
char *name = "oh";
char *name1 = "h2o<l>";
j = mixture_specie_index(m,name);
k = mixture_specie_index(m,name1);
convoh=(0.424-C_YI(c,t,j))/0.424;/*the comversion of oh*/
convw=(0.0127-C_YI(c,t,k))/0.0127;/*the comversion of h2o<l>*/
q=AOH*exp(-EOH/Rg/C_T(c,t))*coh0*(1.-convoh)*(cn0-2.*cw0*convw-coh0*convoh);/*The coh0*dXoh/dt*/
n=Aw*exp(-Ew/Rg/C_T(c,t))*cw0*(1.-convw);/*The cw0*dXw/dt*/
source = delhyd*q+delwat*n;/*The cw0*dXw/dt*delwater+coh0*dXoh/dt*delhyd*/
dS[eqn]=0;
return source;
And I'm getting the errors when building the libudf:
..\..\src\energy_source1.c(30) : error C2143: syntax error : missing ')' before ';'
..\..\src\energy_source1.c(30) : error C2100: illegal indirection
..\..\src\energy_source1.c(30) : error C2143: syntax error : missing ';' before '/'
..\..\src\energy_source1.c(30) : warning C4552: '*' : operator has no effect; expected operator with side-effect
..\..\src\energy_source1.c(30) : warning C4552: '-' : operator has no effect; expected operator with side-effect
..\..\src\energy_source1.c(30) : error C2143: syntax error : missing ';' before ')'
..\..\src\energy_source1.c(31) : error C2143: syntax error : missing ')' before ';'
..\..\src\energy_source1.c(31) : error C2100: illegal indirection
..\..\src\energy_source1.c(31) : error C2143: syntax error : missing ';' before '/'
..\..\src\energy_source1.c(32) : error C2100: illegal indirection
..\..\src\energy_source1.c(32) : warning C4552: '+' : operator has no effect; expected operator with side-effect
Can anyone help me??
lxlxlxt is offline   Reply With Quote
Old   February 10, 2014, 14:19
pakk will become famous soon enough
The #defines that you start with are wrong.
Instead of
#define Aw 1385.;
you should use
#define Aw 1385.
so without the semicolon ( ; ) at the end. The same for all those definitions.
The (pre-)compiler will replace things literally. So when you wrote
q=AOH*exp(...
the pre-compiler sees "AOH", remembers that this should be replaced by "1.7348;", and the result is
q=1.7348;*exp(...
This is giving the errors.
lxlxlxt likes this.
pakk is offline   Reply With Quote
Old   February 10, 2014, 19:56
Michigan
Thank you so much for your reply pakk
compiling, source term, udf
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
