June 25, 2014, 21:44 |
UDF for oscillatory motion
NGH
Rep Power: 15 |
I have write the following UDF and using NACA 0012 as the fish geometry. The UDF compiled without error in Fluent but the foil does not move at all. Im doing a 2D case. What could be the issue? Any advice is greatly appreciated. Thanks
#include "udf.h" DEFINE_GRID_MOTION(upper,domain,dt,time,dtime) { Thread *tf=DT_THREAD(dt); face_t f; Node *v; real amp,omega, delta_y; amp=0.05; omega=5; int n; SET_DEORMING_THREAD_FLAG(THREAD_T0(tf)); begin_f_loop(f,tf) { f_node_loop(f,tf,n) { v=F_NODE(f,tf,n); if(NODE_POS_NEED_UPDATE(v)) { NODE_POS_UPDATED(v); delta_y=amp*sin(omega*time); NODE_Y(v)=NODE_Y(v)+delta_y; } } } end_f_loop(f,tf); } |
Display Zone motion of a dynamic mesh????Checking my UDF motion | Irenedea | FLUENT | 0 | March 20, 2014 02:17 |
UDF for creating motion to a body using a source file. | jayjay | Fluent UDF and Scheme Programming | 1 | August 18, 2012 21:05 |
UDF to control motion NOT about CG | LenDawg0220 | Fluent UDF and Scheme Programming | 0 | July 28, 2012 12:54 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
UDF error CG Motion | Alex | FLUENT | 0 | March 22, 2006 17:40 |
