fluent batch/parallel error
Old   November 7, 2014, 10:26
Default fluent batch/parallel error
Jenifer
768643480 is on a distinguished road
hello, I had write a script file for unsteady flow simulation. The script defines to read fluent *.cas and *.dat files, define the time-step size as 0.0001(seconds) and run a total number of 10000 time steps with a max 20 iterations per time step. The script is below,
/file/rcd zhu-20-2500-f01-rec.cas
/solve/set/time-step 0.0001
/solve/dual-time-iterate 1000 20
/file wcd zhu-20-2500-f01-rec-1.cas
/exit
y
but when I run it, the error will appear:
]nvalid command [
Error: eval: unbound variable
Error Object: 0.0001
Invalid time
time step (s) [0.0001]
Error Object: /solve/dual-time-iterate
/solve/dual-time-iterate Invalid time
1000 20
]nvalid command [20
How could I to correct the script? Thank you very much!
768643480 is offline   Reply With Quote
Old   November 10, 2014, 09:49
pakk will become famous soon enough
After reading the cas and dat files, is the simulation set to transient or steady?
It should be transient, but the warning you see might indicate it is set to steady. If that is the problem, you can solve it by clicking "transient" in the general tab, before you continue. I don't know the Text command to do this.
pakk is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
