UDF for pitching and rotating airfoil
Old   November 20, 2014, 08:32
Default UDF for pitching and rotating airfoil
Select One
guidofrate is on a distinguished road
hi all, my problem is that the UDF that i'm using doesn't work:
#include "udf.h"
DEFINE_ZONE_MOTION(pitching_blade1,omega,axis,orig in,velocity,time,dtime)
real theta0, thetap1, omegaair, omegarot, radius;
omegaair = 10*sin(time) ; /* arbitrary sine function*/
omegarot = 5.4 ; /* velocity of rotor [radians/s] */
theta0 = M_PI/2; /* initial angular position of blade origin [radians] */
radius = 0.5; /* radius of rotor */
thetap1 = omegarot*(time+dtime); /* angular change from initial position at t+dt */
*omega = omegaair; /* pitching velocity of blade */
/* time-varying origin of the local rotor zone coordinates in meters */
origin[0] = radius*cos(theta0+thetap1);
origin[1] = radius*sin(theta0+thetap1)-0.5;
origin[2] = 0.0;
i'm trying to make the airfoil on top (see picture) (i assume that his initial position is pi/2 rads (i'm right?))rotate around the centre of rotation of the ring, that is (0;-0.5), and ,at the same time, rotate around a moving-centre-of-rotation (the centre of the circular zone in which the airfoil is).
so, the fixed centre of rotation is (0;-0.5), the moving-centre-of-rotation is the point that i'm trying to define with:
origin[2] = 0.0;
unfortunately, when i do "preview mesh motion", i see that the airfoil "rotates away" from his hole in the rotating ring.
i tried to use "relative specification" and "link" the airfoil to the ring, but it rotates away again.
well, i hope that some one can answer me.
P.S. i take this UDF from another post, and the person who received this udf get the same problem, so i think that the UDF is wrong, but it seems perfect: what miss?
P.P.S even if its not visible (due to image quality) the interface beetween the "airfoil-zone" and the ring is present.
guidofrate is offline   Reply With Quote
rotating and pitching UDF - need someone to double-check this daysley Fluent UDF and Scheme Programming 13 September 11, 2022 11:04
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 15:33
Rotating Airfoil appa OpenFOAM Running, Solving & CFD 1 June 26, 2012 19:45
UDF for Airfoil in Circular motion (2D) sohail_27 Fluent UDF and Scheme Programming 4 October 4, 2010 13:36
UDF for a sinusoidal rotation of an airfoil Lorenzo FLUENT 2 October 10, 2008 10:37
