Modelling porosity as a function of temperature
Like Tree1Likes
  • 1 Post By macfly
Old   January 2, 2015, 10:29
Default Modelling porosity as a function of temperature
Anonymous Joe
woody85 is on a distinguished road
In my case i want to model the porosity as a function of temperature. my code looks like this:
#include "udf.h"
DEFINE_PROFILE{dir1, t, i}
	cell_t c;
	begin_c_loop(c,t)
		real temp = C_T(c,t);
		if (temp > 1300.)
			C_PROFILE(c,t,i) = 13.7 - (temp - 1300) * 0.0015 + pow(temp - 1300,2.) *0.0000075;
		else if (temp > 1500.)
			C_PROFILE(c,t,i) = 0.01;
		else
			C_PROFILE(c,t,i) = 13.7;
	end_c_loop(c,t)
 DEFINE_PROFILE{dir2, t, i}
	cell_t c;
	begin_c_loop(c,t)
		if (temp > 1300.)
			C_PROFILE(c,t,i) = 13.7 - (temp - 1300) * 0.0015 + pow((temp - 1300),2.0) *0.0000075;
		else
	end_c_loop(c,t)
But i always get the following error:
New_UDF.c.8748.5.c: line 8: parse error.
which is a little bit confusing.
thx for your help
woody85 is offline   Reply With Quote
Old   January 5, 2015, 10:14
François Grégoire
macfly is on a distinguished road
- the accolades should be replaced with parentheses
- you should not use "temp" because it shadows previous definition
cell_t c;
begin_c_loop(c,t)
if (temp > 1300.)
else
end_c_loop(c,t)
cell_t c;
begin_c_loop(c,t)
if (temp > 1300.)
else
end_c_loop(c,t)
woody85 likes this.
macfly is offline   Reply With Quote
Old   January 7, 2015, 05:27
Anonymous Joe
thx for your help - now it seems to work !
Old   January 13, 2015, 03:33
Anonymous Joe
Is this formulation of the UDF also valid for transient simulations ?
Old   January 13, 2015, 06:48
François Grégoire
Yes it is valid.
Old   January 13, 2015, 08:43
Anonymous Joe
Originally Posted by macfly View Post
Yes it is valid.
Thx, i only have one problem left, i want to model more or less a simplified melting process of a porous media. The lines i posted are only a part of my code.
So far the melting is built up correctly, but when for some reason the temperatur in my cell decreases, the whole thing is reversible, which in my case is not realistic, as the molten liquid, flows to the bottom.
I want to ensure, that once my cell reached a certain temperature, the porosity cannot decrease again.
Old   January 13, 2015, 19:30
François Grégoire
I don't understand why you code dir1 and dir2 since the equation/conditions are the same. Code only one DEFINE_PROFILE and load the same property for both directions.
Porosity should be between 0 and 1, values like 13.7 and the jump at 1500 look weird.
Regarding the reversibility problem, you will have to store previous timestep values in a UDMI and compare them with current timestep values. Then write some if condition that keeps the porosity constant if T current timestep < T previous timestep. See this post for an example: http://www.cfd-online.com/Forums/flu...tml#post372530
Old   January 14, 2015, 03:26
Anonymous Joe
First of all thanks for your help.
As i mentioned this is only a part of my code, i don´t wanted to upload the whole thing here because it´s to long. In the code i also modelled the pressure drop. Actually i copied the line for the inertial resistance. This is not identical in all directions in my case at the beginning. Therefore i had to use two values. Nevertheless the code for the porosity looks exactly the same onle the values change, they have to be between 0 and 1, as allready mentoined by you.
Thanks for the help regarding the reversibility problem. I will have a closer look on this.
Old   January 14, 2015, 04:56
Anonymous Joe
Dear MacFly, thx for your help.
The condition you suggested will not work out:
"Then write some if condition that keeps the porosity constant if T current timestep < T previous timestep"
because this condition would only work for 1 timestep. if i have temperature decrease for more timesteps, the condition would only look for the last timestep and can´t know that my material is allready melted e.g. 10 timesteps ago.
Therefor i suggested to take the porosity itself as condition. If the porisity 1 timestep ahead =1, then it should also be 1 in the next timestep. unfortunatly this doesnt work out so well yet, mainly to my lack of udf-experience.
my actual version of the UDF now looks like this:
 DEFINE_PROFILE(por, t, i)
	cell_t c;
	begin_c_loop(c,t)
		real val_temp = C_T(c,t);
		if (val_temp > 1500.)
				C_PROFILE(c,t,i) = 1;
				C_UDMI(c,t,1) = 1;
		else if (val_temp > 1300. && val_temp < 1500.)
				C_PROFILE(c,t,i) = val_temp*0.000425 + 0.3575;
				C_UDMI(c,t,1) = val_temp*0.000425 + 0.3575;
		else
				C_PROFILE(c,t,i) = 0.91;
				C_UDMI(c,t,1) = 0.91;
		C_UDMI(c,t,0) = C_UDMI(c,t,1) /*not working */
	end_c_loop(c,t)
The idea was to store the actual value of the porosity in den UDMI, and at the end i want to store the actual value of the UDMI, so that i can use the values in the next timestep (not working yet). Here i made an mistake.
The next steps would be to make an if condition, to check if the porosity in the timestep before was 1 or not, if the value was 1, then overwrite the actual value of the cell with the value 1.
Old   January 14, 2015, 09:55
ghost82's Avatar
Rick
ghost82 will become famous soon enough
If you need to know if material was already melted what about using a boolean variable?
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
