January 7, 2015, 22:18 |
UDF simulate a laser beam in flow field
MI
Rep Power: 12 |
I am looking for information about how to use UDF function to simulate laser beam inside a flow field. Based on the information i collected right now, i can treat laser beam as a heat source and MACRO_SOURCE may be one option to define a spatial heat source in cell zone. And for heat source intensity distribution, gauss distribution may be something i can look into. does someone has experience about this topic? I really want to know am i in the right direction or there is some other method for laser beam simulation. Thanks ahead, Xu |
How to simulate a flow field where a rotating object travelling? | SJSW | ANSYS | 0 | July 22, 2014 01:25 |
UDF for fully developed turbulent flow at inlet | soroushsaberi | FLUENT | 0 | May 28, 2014 17:00 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
Nonphysical flow field while using coodles solver | ankgupta8um | OpenFOAM Running, Solving & CFD | 5 | January 26, 2008 16:54 |
rerun with same flow field, different fluid props | Tim | Phoenics | 0 | March 3, 2004 14:51 |
