DPM, evaporated droplets do not show up in continues phase |
January 18, 2015, 17:45 |
Marnoq
Hi everyone,
I have a converged continues model with Ar flow, mainly based on UDF files. When I introduced some atomiccopper droplets via DPM, they are all tracked and evaporated: but they do not show up in the continues phase. I need them as the gas atoms for further studies. (the interaction icon between DPM+Continues is "on"). I gave the cu-gas-properties in a UDF file as well as for Ar. The copper UDF works well when I introduce the copper as a gas flow from the inlet in continues phase (as a test) Now I need the evaporated copper droplets to be counted as copper-gas. It seem's there is a link missed between evaporated particles from DPM and the continues gas phase. Any hint? Thank you in advance |
dpm fluent, udf dpm |
DPM - droplets | John | FLUENT | 4 | August 21, 2005 00:12 |
DPM coupling steps | kiao | FLUENT | 5 | June 23, 2005 11:04 |
The minimum diameter of second phase in the DPM | Fluenter | FLUENT | 2 | August 15, 2004 06:46 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
steady or unsteady? (in dpm) | winnie | FLUENT | 1 | April 28, 2003 11:30 |
