UDF "Define_On_Demand" error: "Segmentation Violation"
Like Tree4Likes
  • 1 Post By pakk
  • 1 Post By upeksa
  • 1 Post By upeksa
  • 1 Post By upeksa
Old   February 3, 2015, 03:23
Default UDF "Define_On_Demand" error: "Segmentation Violation"
Anh
dinhanh is on a distinguished road
Hi, Fluent UDF user,
This is the same question as previous thread: Hooking On_Demand error.
I re-wrote new code, the compiler and loading UDF is OK. But when the code hooked, It showed the proplem as in the picture below (pic.12 is the compiler successful, pic.11 is the error).
Could you please help me solve this problem??
Thank you very much.
#include "udf.h"
#include "math.h"
DEFINE_ON_DEMAND(contour)
Domain *d;
Thread *t;
cell_t c;
Node *v;
d=Get_Domain(1);
int i,j,k,n,m;
real dx,dy,dz,delta,Cdes=0.65,Lt,Ldes;
thread_loop_c(t,d) /*loops over all cell threads in domain*/
begin_c_loop(c,t) /* loops over cells in a cell thread */
c_node_loop(c,t,n) /* loops over node in a cell thread */
v=C_NODE(c,t,n);
NODE_MARK(v)=0;
end_c_loop(c,t)
k=C_NNODES(c,t);
real x[k],y[k],z[k];
real delx1=0,dely1=0,delz1=0;
for (m=0;m<=k;m++)
v=C_NODE(c,t,n);
x[m]=NODE_X(v);
y[m]=NODE_Y(v);
z[m]=NODE_Z(v);
if (NODE_MARK(v)==0)
NODE_MARK(v)=1;
for (i=0;i<=k;i++)
for (j=0;j<=k;j++)
dx=MAX(delx1,fabs(x[i]-x[j]));
dy=MAX(dely1,fabs(y[i]-y[j]));
dz=MAX(delz1,fabs(z[i]-z[j]));
delta=MAX(dx,dy);
delta=MAX(delta,dz);
Lt=sqrt(C_K(c,t))/0.09/C_O(c,t);
Ldes=Cdes*delta;
if(Lt>Ldes)
C_UDMI(c,t,1)=1;
if(Lt<=Ldes)
C_UDMI(c,t,1)=0;
end_c_loop(c,t)
dinhanh is offline   Reply With Quote
Old   February 3, 2015, 03:36
pakk will become famous soon enough
I would suggest to comment out some parts, so you can determine where in the code the problem is. (Like this.)
dinhanh likes this.
pakk is offline   Reply With Quote
Old   February 3, 2015, 07:05
Anh
Thank you, Pakk,
But I could not get your answer, Please help, this one very importance for me!!!
Old   February 3, 2015, 07:23
Your code has a mistake. Remove half of the code, and see if you still get an error. If you get the error, then the mistake is in the remaining code. If you don't get an error, the mistake is in the part you removed.
Repeat this until you found the error.
Old   February 3, 2015, 09:46
upeksa is on a distinguished road
I don't really know what are you trying, you have a lot of useless code here.
It works now anyway.
#include "udf.h"
#include "math.h"
Domain *d=Get_Domain(1);
Thread *t;
cell_t c;
Node *v;
int i,j,k,n,m;
real *x, *y, *z;
real delx1=0.,dely1=0.,delz1=0.;
thread_loop_c(t,d)
begin_c_loop(c,t)
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
CLEAR_NODE_VISITED(v);
end_c_loop(c,t)
begin_c_loop(c,t)
k=C_NNODES(c,t);
x=(real *)malloc(k*sizeof(real));
y=(real *)malloc(k*sizeof(real));
z=(real *)malloc(k*sizeof(real));
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
x[n]=NODE_X(v);
y[n]=NODE_Y(v);
z[n]=NODE_Z(v);
if (!(NODE_IS_VISITED(v)))
SET_NODE_VISITED(v);
for (i=0;i<=k;i++)
for (j=0;j<=k;j++)
delta=MAX(dx,dy);
Ldes=Cdes*delta;
if(Lt>Ldes)
C_UDMI(c,t,1)=1;
if(Lt<=Ldes)
C_UDMI(c,t,1)=0;
free(x);
free(y);
free(z);
end_c_loop(c,t)
dinhanh likes this.
upeksa is offline   Reply With Quote
Old   February 3, 2015, 10:09
Anh
Thank you so much, upeksa,
I am trying to plot the contour in which the region of LES will be 0 and the region of RAN will be 1. I am using DES turbulence model. So in order to do thay, I need to calculate the max grid size of each cell, and compear that one to lenght scale of k-omega model. That is what I am doing now.
Old   February 3, 2015, 10:28
Did you know that you can use the macro C_VOLUME(c,t) to check the cell volume of each cell?
Old   February 3, 2015, 10:32
Anh
Yes, I known. But what I need here is the max grid size, not the the vollume of cell. I mean, at each cell, I need to find delta=max(dx,dy,dz)
Old   February 3, 2015, 22:01
Anh
#include "udf.h"
#include "math.h"
Thread *t;
cell_t c;
Node *v;
int i,j,k,n,m;
real *x, *y, *z;
thread_loop_c(t,d)
begin_c_loop(c,t)
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
end_c_loop(c,t)
begin_c_loop(c,t)
k=C_NNODES(c,t);
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
x[n]=NODE_X(v);
y[n]=NODE_Y(v);
z[n]=NODE_Z(v);
for (i=0;i<=k;i++)
for (j=0;j<=k;j++)
delta=MAX(dx,dy);
Ldes=Cdes*delta;
if(Lt>Ldes)
C_UDMI(c,t,1)=1;
if(Lt<=Ldes)
C_UDMI(c,t,1)=0;
free(x);
free(y);
free(z);
end_c_loop(c,t)
Dear upeksa,
I Tried to use your code and modified a little. But It still did not work. The same error appeared. I dont know why It have no error in your case
#include "udf.h"
#include "math.h"
Thread *t;
cell_t c;
Node *v;
int i,j,k,n;
real delta,Cdes=0.65,Lt,Ldes;
real *x, *y, *z;
thread_loop_c(t,d)
begin_c_loop(c,t)
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
end_c_loop(c,t)
begin_c_loop(c,t)
k=C_NNODES(c,t);
real dx=0.,dy=0.,dz=0.;
c_node_loop(c,t,n)
v=C_NODE(c,t,n);
x[n]=NODE_X(v);
y[n]=NODE_Y(v);
z[n]=NODE_Z(v);
for (i=0;i<=k;i++)
for (j=0;j<=k;j++)
dx=MAX(dx,fabs(x[i]-x[j]));
dy=MAX(dy,fabs(y[i]-y[j]));
dz=MAX(dz,fabs(z[i]-z[j]));
delta=MAX(dx,dy);
Ldes=Cdes*delta;
if(Lt>Ldes)
C_UDMI(c,t,1)=1;
if(Lt<=Ldes)
C_UDMI(c,t,1)=0;
free(x);
free(y);
free(z);
end_c_loop(c,t)
Old   February 4, 2015, 02:13
Anh
I also tried with the more simple code, But still got same error.
So I dont know what happened
#include "udf.h"
#include "math.h"
#include "stdlib.h"
#include "malloc.h"
Thread *t;
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
delta=pow(C_VOLUME(c,t),1./3);
Ldes=Cdes*delta;
if(Lt>Ldes)
C_UDMI(c,t,1)=1;
if(Lt<=Ldes)
C_UDMI(c,t,1)=0;
end_c_loop(c,t)
Old   February 4, 2015, 04:24
Do you have two two user defined memories (UDMS) defined in Fluent?
Old   February 4, 2015, 04:49
Anh
Thank, pakk,
What do you mean?
Old   February 4, 2015, 05:28
I think something is wrong with C_O(c,t).
I have change it for C_T(c,t) for example and it worked.
Old   February 4, 2015, 06:01
Anh
For me, even, I changed C_O(c,t) by 5, for example, still got same error.
And in the simple code upper, the same error appeared. But when I compiler UDF for vapor pressure, It ran well, no error.
So it seem to be have problem in my PC. I am using super-comp at University.
If you dont mind, Could you use example Fluent file, and use this UDF code to plot the data?
http://www.filedropper.com/desktop_61
Thank you
Old   February 4, 2015, 07:31
You haven't reserved UDF memories:
Define -> User-Defined -> Memory... Number of User-Defined Memory Locations =2
It will work
dinhanh likes this.
Old   February 4, 2015, 09:34
Anh
It will work
Thank you very much, upeksa,
It work now. So the problem is the number of memory location. How can we determine how many memory location will be needed?
Old   February 4, 2015, 09:37
You used C_UDMI(c,t,0) and C_UDMI(c,t,1). 2 memory locations.
Old   February 4, 2015, 09:41
Anh
From the UDF code, I used only one memory user define location with If loops
If (a<b) C_UDMI(c,t,1)=1
If (a>b) C_UDMI(c,t,1)=0
So I think only 1 location is required?
Old   February 4, 2015, 09:55
No, you still need 2.
if you only use 1 memory location whose number is, for example 11 (C_UDMI(c,t,11)), you will need in that case 12 memory locations.
If you are going to use only one memory location, use C_UDMI(c,t,0) instead.
dinhanh likes this.
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 07:29
UDF for Mass Flow at the Outlet: ERROR ACCESS VIOLATION I-mech Fluent UDF and Scheme Programming 1 May 23, 2014 12:37
udf segmentation violation when hooked jjchristophe Fluent UDF and Scheme Programming 9 June 25, 2012 05:46
udf error : access violation butterfly007 Fluent UDF and Scheme Programming 2 June 1, 2012 11:01
UDF Access violation therandomestname FLUENT 0 April 15, 2011 17:31
