Udf to define new mixing law between properties of different phases in Mixture model
Old   February 24, 2015, 03:23
Default Udf to define new mixing law between properties of different phases in Mixture model
saurabh gupta
saurabhg2014 is on a distinguished road
As far as i know that Mixture model uses mixture rule to formulate a property of mixture from different phase properties but if i have to define any different relationship among phase material properties then which Macro (DEFINE PROPERTY ??) should i use to write UDF and where it will be hooked up ...i mean in individual phase properties or somewhere else in FLUENT.
In my case mixture viscosity is a function of two primary and secondary phase viscosity but this function is not mixing law.Any help?
saurabhg2014 is offline   Reply With Quote
UDF for defining granular viscosity in mixture model priyanka.asp Fluent UDF and Scheme Programming 7 May 19, 2019 18:16
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
mixture model or multiphase model in my UDF? aleisia Fluent UDF and Scheme Programming 0 June 8, 2011 13:25
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
