The fl process could not be started because of UDF
Like Tree4Likes
  • 4 Post By majid_kamyab
Old   March 2, 2015, 11:10
Unhappy The fl process could not be started because of UDF
majid kamyab
majid_kamyab is on a distinguished road
Hello
I am having this problem with ansys fluent 15.07. when I tried to read a case and data which was built and run in fluent 14. the following error happened.
Reading "C:\kamyab\from new 32 cpu check\bestfit1-118-754580.dat"...
2 user-defined node memory locations, 252178 nodes, binary.
Parallel variables...
Node 0: Process 2516: Received signal SIGSEGV.
Node 4: Process 3156: Received signal SIGSEGV.
Node 1: Process 6020: Received signal SIGSEGV.
Node 5: Process 5960: Received signal SIGSEGV.
Node 6: Process 2564: Received signal SIGSEGV.
Node 2: Process 3152: Received signal SIGSEGV.
Node 7: Process 4840: Received signal SIGSEGV.
Node 3: Process 5892: Received signal SIGSEGV.
unable to read the cmd header on the pmi context, Error = -1
Error posting readv, An existing connection was forcibly closed by the remote host.(10054)
received suspend command for a pmi context that doesn't exist: unmatched id = 7
received suspend command for a pmi context that doesn't exist: unmatched id = 6
received suspend command for a pmi context that doesn't exist: unmatched id = 5
job aborted:
rank: node: exit code[: error message]
0: admin-PC: 2: process 0 exited without calling finalize
1: admin-PC: 2: process 1 exited without calling finalize
2: admin-PC: 2: process 2 exited without calling finalize
3: admin-PC: 2: process 3 exited without calling finalize
4: admin-PC: 2: process 4 exited without calling finalize
5: admin-PC: 2: process 5 exited without calling finalize
6: admin-PC: 2: process 6 exited without calling finalize
7: admin-PC: 2: process 7 exited without calling finalize
received suspend command for a pmi context that doesn't exist: unmatched id = 4
received suspend command for a pmi context that doesn't exist: unmatched id = 3
received suspend command for a pmi context that doesn't exist: unmatched id = 1
received suspend command for a pmi context that doesn't exist: unmatched id = 0
The fl process could not be started.
the problem is about the UDFs. I have tried these UDFs on fluent 14 and fluent 15.07 in two different occasions.
I have run this case and data in fluent 14 for many many iterations.
I also run this case in fluent 15.07 from the beginning ( I mean init)
so I am sure that UDF are fine.
also I am sure that the problem is with the UDFs. because when I diactiveate them there will be no errors.
please help
majid_kamyab is offline   Reply With Quote
Old   April 16, 2015, 05:51
majid kamyab
its because of double precision. try to run the case with and without double precision.
this took me about 12 days to understand
zhixin, Oula, liangerscu and 1 others like this.
Old   July 1, 2015, 03:36
Default error when itterrate with UDRGM
faegheh
fafa_blues is on a distinguished road
hi,i worked a lot with fluent 14.5 and 15 but I could not even compile my UDF (actually it is UDRGM) and then shift it to fluent 6.3 and finally could compile my UDRGM with this words:
Loading Real-EQUILIBRIUM_GAS Library:
Setting material "air" to a real-gas...
then I wanted iterate it but I got some error (with double decision running) and then shift it to single decision and again got error and this the massage:
unable to read the cmd header on the pmi context, generic socket failure, error stack:
MPIDU_Sock_wait(2533): The specified network name is no longer available. (errno 64).
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytesunable to read the cmd header on the pmi context, generic socket failure, error stack:
: No such file or directory
job aborted:
0: msc9.aero.edu: -1073741819: process 0 exited without calling finalize
1: msc9.aero.edu: -1073741819: process 1 exited without calling finalize
2: msc9.aero.edu: -1073741819: process 2 exited without calling finalize
3: msc9.aero.edu: -1073741819: process 3 exited without calling finalize
4: msc9.aero.edu: -1073741819: process 4 exited without calling finalize
5: msc9.aero.edu: -1073741819: process 5 exited without calling finalize
6: msc9.aero.edu: -1073741819: process 6 exited without calling finalize
7: msc9.aero.edu: -1073741819: process 7 exited without calling finalize
received suspend command for a pmi context that doesn't exist: unmatched id = 2
The Parallel FLUENT process could not be started.
I don't know that is wrong, could you please help
fafa_blues is offline   Reply With Quote
Old   July 1, 2015, 04:49
majid kamyab
job aborted:
first of all you cannot use case and data of a a newer version of fluent for an older one
secondly, what was ur problem about compiling in fluent 14.5 and 15?
Old   July 1, 2015, 05:56
faegheh
[QUOTE=majid_kamyab;552819]first of all you cannot use case and data of a a newer version of fluent for an older one
secondly, what was ur problem about compiling in fluent 14.5 and 15?[/QUOTE
thanks for ur replying
when i work with fluent 14.5 serial it compile my UDRGM but not load it and these are the massages :
Error:
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.7\win6 4\3ddp\fl1457s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
but when use parallel version of fluent 14.5 the error for loading is this:
Opening user-defined realgas library "libudf"...
Library "libudf\win64\3ddp_host\libudf.dll" opened
Library "libudf\win64\3ddp_node\libudf.dll" opened
Setting material "real-gas-fluid" to a real-gas...
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
Message from Cortex process==> Connection with host is broken. It may have crashed.
but in fluent 6.3 i compile and load successfully but i can not use my code i mean when i want to start iteration some error appear
Old   December 15, 2015, 00:15
abed
toghay is on a distinguished road
[QUOTE=fafa_blues;552839]
Error:
Error Object: #f
Hi majid_kamyab,
Have you solved your problem? Actually I have the same problem as yours. If you find the solution, would you please tell me? Thanks.
toghaya@gmail.com
toghay is offline   Reply With Quote
Old   December 15, 2015, 08:42
Default solving the problem
faegheh
[QUOTE=toghay;577597]
Hi majid_kamyab,
toghaya@gmail.com
hi
i have found the problem and it was about my code,accually i have changed the code, these kind of errors are because fluent can not access to the right information to give data / or / code ask for wrong type of data, so it can not give any data to solve the equation.
i hope it will help
fluent 14 to fluent 15., sigsegv, udf
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
How to simulate the process of water evaporation by UDF? qiyang860908 Fluent UDF and Scheme Programming 10 January 9, 2015 13:59
UDF error vagaikwa Fluent UDF and Scheme Programming 1 March 20, 2013 03:11
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
how to interrupt the process of solver with udf? endlessfree Fluent UDF and Scheme Programming 0 March 24, 2010 05:48
