Problem using UDF
Old   July 23, 2015, 13:35
Smile Problem using UDF
Ali
hello77 is on a distinguished road
Hello everyone,
I'm trying to simulate the flow around a multi tubes and fins heat exchanger in starting up condition, transient, using Fluent. The input conditions for water and air are given using the UDF shown below.
When the simulation was run, the water and air inlet temperatures did not change according to the UDF. I mean they keep changing using the equations in the first interval (from 0 to 8000 sec) and did not go to the second condition even the running time was greater than 8000 sec. My experience is very limited in programming with C language and I guess there something wrong with the UDF!
I appreciate your help to solve this issue.
UDF:
#include "udf.h"
DEFINE_PROFILE(RAMP_waterIN, thread, position)
float t, waterIN;
face_t f;
t = RP_Get_Real("flow-time");
if (0 < t < 8000)
{ waterIN = (-0.00000000007*(t*t*t))+(0.0000005*(t*t))+(0.0052*t )+296.071;
else if (8000 <= t <= 10000)
{ waterIN = 333;
begin_f_loop(f, thread)
F_PROFILE(f, thread, position) = waterIN;
end_f_loop(f, thread)
DEFINE_PROFILE(RAMP_airIN, thread, position)
float t, airIN;
face_t f;
if (0 < t < 8000)
{ airIN = (-0.000000000006*(t*t*t))+(0.00000006*(t*t))+(0.0002 *t)+292.23;
{ airIN = 294.91;
F_PROFILE(f, thread, position) = airIN;
hello77 is offline   Reply With Quote
Old   July 24, 2015, 02:59
Jack
kamer is on a distinguished road
Try to change
if (0 < t < 8000) to if (0<t&&t<8000),
use && as "and" in C language.
other sentences can be treated as the same.
kamer is offline   Reply With Quote
Old   July 24, 2015, 03:00
Jack
Try to change
Old   August 3, 2015, 09:52
Default thank you
Ali
Thank you kamer. its working now.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
