Problems with UDF in parallel mode
Old   October 2, 2015, 08:48
Question Problems with UDF in parallel mode
Rikard
rikfr986 is on a distinguished road
Hi!
I have written a UDF to calculate the average value of a passive scalar at the outlet boundary to use it as a prescribed value at the inlet. The code works fine when in serial mode but not in parallel. seems like only one of the cores got the right value!? or how to express it.
Would be very pleased if someone knows what's wrong or could guide me in right direction!
see code below
#include "udf.h"
#include "mem.h"
real concavg, concavg1;
real conc;
DEFINE_EXECUTE_AT_END(out_ave)
Domain *d;
real area,
real area_tot;
real A[ND_ND];
Thread *t;
face_t f;
d=Get_Domain(1);
t=Lookup_Thread(d,5);
area=0;
area_tot=0;
conc=0;
concavg=0;
concavg1=0;
begin_f_loop(f,t)
F_AREA(A,f,t);
area=NV_MAG(A);
area_tot+=area;
conc=F_UDSI(f, t, 0);
concavg += conc*area;
concavg1=concavg/area_tot;
printf("\n area_tot = %f\n",area_tot); /*print once for every cell face on outlet, counts to the right area, OK!*/
printf("\n concavg = %f\n",concavg1); /*print once for every cell face on outlet, right value, OK!*/
end_f_loop(f,t)
printf("\n area_tot2 = %f\n",area_tot);/* Print once for every core, first one OK the other three =0??!*/
printf("\n concavg2 = %f\n",concavg1);
DEFINE_PROFILE ( inl_uds, t, i)
face_t face;
face_t f;
real flow_time, inlvalue;
flow_time=RP_Get_Real("flow-time");
if(flow_time<0.5)
begin_f_loop(face, t)
F_PROFILE(face, t, i)=1;
end_f_loop(face, t)
else
inlvalue=concavg1;/*F_UDMI(f,t,0);*/
F_PROFILE(face, t, i)=inlvalue;
end_f_loop(face, t)
rikfr986 is offline   Reply With Quote
Old   October 6, 2015, 11:17
Bruno
brunoc is on a distinguished road
The documentation has a section about parallelizing UDFs. You can't just use the version you use in serial, since part of the information can't be accessed by all compute nodes.
For instance, the averaging procedure you're doing won't work since some of the compute nodes might not have any cells on the zone you're looking for. That is why you're getting a null area on some partitions.
Search for Global Reduction Macros in the doc and make the appropriate corrections (but read the entire parallel section to know other things you'll need to change).
Cheers.
brunoc is offline   Reply With Quote
parallel, scalar, udf
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 06:23
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
compiling UDF for moving mesh in parallel mode vespa50l Fluent UDF and Scheme Programming 3 September 22, 2014 11:11
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 04:31
