UDF code for heat generating source
Like Tree7Likes
  • 1 Post By krushna
  • 1 Post By pakk
  • 1 Post By pakk
  • 1 Post By pakk
  • 1 Post By pakk
  • 1 Post By kcgmech
  • 1 Post By bhargavbharathan
Old   October 23, 2015, 08:07
Unhappy UDF code for heat generating source
yashar_aryanfar
valerhain is on a distinguished road
hi dear friends
I am supposed to write a udf for heat generation rate which is a function at this form:
I prepared this code for simulating :
#include "udf.h"
#define EPS 0.01
#define SIGMA 0.004
DEFINE_SOURCE(cell_x_source, cell, thread, dS, eqn)
real x[ND_ND];
real source;
C_CENTROID(x,cell,thread);
source=EPS*exp(((x[0]-0.4)*(x[0]-0.4)+(x[1]-0.004)*(x[1]-0.004))/(-SIGMA*SIGMA));
dS[eqn]=0;
return source;
but is not work. this code dont have any effect in my results. dear friend I have less than 5 days for simulating this. please help me and I will thankfull of you...
valerhain is offline   Reply With Quote
Old   October 27, 2015, 02:14
krushna shekde
krushna is on a distinguished road
hi yashar,
i think first you define scalar for x[0] and x[1] and also write udf for initialization of x[0] and x[1]
regards,
krushna
valerhain likes this.
krushna is offline   Reply With Quote
Old   October 28, 2015, 06:31
pakk will become famous soon enough
It is not about x[0] and x[1], they are defined in the code and you don't need a udf to initialize them.
Can you tell us what you did with the code?
You saved it in a text file, and then what? How did you tell Fluent to use this code?
(And are you sure that the source locus, (x0,y0)=(0.4,0.004), is in your domain?)
pakk is offline   Reply With Quote
Old   October 28, 2015, 07:06
yashar_aryanfar
first of all I am very thankful
I have written this code on the notepad and save it with .c format
If you see the pictures that I was adding in first post, I am trying to add this code in energy equation
user define-->function-->interpreted-->and after choosing the file, I have interpreted the code
then I in boundary condition part, I choose fluid and adding the code to the heat source part
I want to this code define a heat source in (0.4.0.004) and affect boundary layer
but unfortunately it is not work and there is heat source effects in the results
as you said I am going to check domain again
Old   October 28, 2015, 07:10
Those seem like good steps...
To check if your code is really used, you can put the following line in:
Message("Test\n");
Put it for example directly above your "return"-line. If you see "Test" appearing in your text user interface, the code is run, and if you don't see it, it is not run.
Another thing you could do is to increase epsilon for testing. Maybe the source is really added, but the effect is too small to notice. Change epsilon from 0.01 to a big value such as 1000, and see if your result changes.
Old   October 28, 2015, 07:26
Unhappy
yashar_aryanfar
Message("Test\n");
I added your code to my UDF and this is what I see :
Error: H:\source.c: line 14: function "CX_Message" not found (pc=128).
Old   October 28, 2015, 07:29
Silly me, you are interpreting, then Message does not work...
Use printf instead.
printf("test\n");
Old   October 28, 2015, 07:44
yashar_aryanfar
Use printf instead.
printf("test\n");
I tried again....there is not any error that be written in the user text interface but the test message also not!
Old   October 28, 2015, 07:48
To be clear: the text should show up when you clicked 'Calculate'.
If it doesn't show up then, the code is never run by Fluent, but I can not explain why not.
Old   October 28, 2015, 07:53
yashar_aryanfar
bingooooooooooooooooooooooooooooooooo
it is works.....when i push calculate buttun many of test!!! letter are written in the interfaaaaaaaaaaaaaaaaace!
yohuuuuuuuuuuuuuuuuuuuuu
Old   October 28, 2015, 08:06
yashar_aryanfar
my Pc works on it
fluent process the problem
so as soon as I see the results I will tell you
dear friend
you are reallllllllllllllly helpful person
thank alooooooooooooooooot
Old   October 31, 2015, 03:56
Ganesh K C
kcgmech is on a distinguished road
hi dear friends
#include "udf.h"
#define EPS 0.01
#define SIGMA 0.004
real x[ND_ND];
real source;
dS[eqn]=0;
return source;
dear valerhain,
what you are trying to do? if you want to include the heat generation source as surface heat flux, you can apply using DEFINE PROFILE...
kcgmech is offline   Reply With Quote
Old   November 18, 2015, 11:55
Bhargav Bharathan
bhargavbharathan is on a distinguished road
I'm not sure if it has been addressed already but I think source UDFs can only be compiled and interpreted.
Bhargav
bhargavbharathan is offline   Reply With Quote
Old   November 18, 2015, 14:24
yashar_aryanfar
Originally Posted by bhargavbharathan View Post
Bhargav
thanks alot dear friend
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 03:40
