UDF Error!!
Old   October 30, 2015, 15:18
Default UDF Error!!
codenamenone
unred486 is on a distinguished road
I keep getting an error message
"999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819"
I searched it online but nothing seems to work.
My UDF code is
// Han Ju lee
// Sarkar Enhanced Correction for k-epsilon model
// from Enhancement of USM3D Unstructured FLow Solver for
//High-Speed
// High-Temperature Shear Flows by Mohagna J.Pandya, Khaled S. //Abdol-Hamid and
// Neal T. Frink
// In this model we added Pressure Dilatation term.
// Modified e equation by comparing standard ke model in fluent // and the equation from the paper stated above.
#include "udf.h"
#include "mem.h"
#include "math.h"
#define alpha2 0.4
#define alpha3 0.2
#define Ce1 1.44
#define Ce2 1.92
#define sigmak 1.0
#define sigmae 1.3
#define Cu 0.09
#define MYSMALL 1e-8
#define MYBIG 1e10
enum{
P,
a,
Mt,
f2,
v,
dudx,
Source,
empty
DEFINE_ON_DEMAND(setnames)
Set_User_Memory_Name(P,"P");
Set_User_Memory_Name(a,"a");
Set_User_Memory_Name(Mt,"Mt");
Set_User_Memory_Name(f2,"f2");
Set_User_Memory_Name(v,"v");
Set_User_Memory_Name(dudx,"dudx");
Set_User_Memory_Name(Source,"Source");
Set_User_Memory_Name(empty,"empty");
DEFINE_SOURCE(source_sarkar,c,t,dS,eqn)
C_UDMI(c,t,P) = C_STORAGE_R(c,t,SV_PRODUCTION);
C_UDMI(c,t,a) = sqrt(1.5*287.058*C_T(c,t));
C_UDMI(c,t,Mt)=sqrt(2.0*C_K(c,t))/MAX(C_UDMI(c,t,a),MYSMALL);
C_UDMI(c,t,Source)= C_UDMI(c,t,P)*(-1.0*alpha2)*pow(C_UDMI(c,t,Mt),2)+(C_R(c,t)*C_D(c, t)*alpha3)*pow(C_UDMI(c,t,Mt),2)+1.0*C_R(c,t)*C_D( c,t)*pow(C_UDMI(c,t,Mt),2);
return C_UDMI(c,t,Source);
DEFINE_SOURCE(e_eq,c,t,dS,eqn)
C_UDMI(c,t,v)=C_MU_L(c,t)/C_R(c,t);
C_UDMI(c,t,f2)=1.0-0.3*exp(-pow(pow(C_K(c,t),2)/(C_UDMI(c,t,v)*C_D(c,t)),2));
C_UDSI(c,t,dudx)=sqrt(C_K(c,t));
C_UDMI(c,t,Source)= Ce2*C_R(c,t)*pow(C_D(c,t),2)/C_K(c,t)-C_UDMI(c,t,f2)*Ce2*C_R(c,t)*pow(C_D(c,t),2)/C_K(c,t)+2.0*C_UDMI(c,t,f2)*Ce2*C_D(c,t)/C_K(c,t)*C_MU_L(c,t)*pow(C_UDSI_G(c,t,dudx)[0]+C_UDSI_G(c,t,dudx)[1],2);
I am a beginner to fluent so I am not sure where to even begin to fix this problem. Could anyone look at this problem?
Thanks
unred486 is offline   Reply With Quote
Old   November 2, 2015, 15:34
`e`
`e` is on a distinguished road
Sounds like this error appears for large meshes opened across multiple computers (source 1, 2). How many cells and computers are you using? If your simulation is working fine in serial mode on a single computer then check with your system administrator about the cluster setup.
`e` is offline   Reply With Quote
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
