a fatal signal (segmentation fault)
Old   November 26, 2015, 06:52
Post a fatal signal (segmentation fault)
angela huang
Turbo_hrf is on a distinguished road
I have written a UDF about standard k-e turbulence model and compiled successfully, but when I try to initialize this code, it shows error: received a fatal signal (segmentation fault)
does anyone help me to remove this problem please?
My UDF code are listed below:
#include "udf.h"
/*#include "math.h"*/
/* Turbulence model constants */
const real C1e=1.44;
const real C2e=1.92;
const real C_mu=0.09;
const real SIG_k=1.0;
const real SIG_e=1.3;
/* User-defined scalars */
enum
TK,
TE,
N_REQUIRED_UDS
/*Define source term in k equation */
DEFINE_SOURCE(TK_SOURCE, c, t, dS, eqn)
real source;
dS[eqn]=0.0;
source= C_MU_T(c,t)*C_STRAIN_RATE_MAG(c,t)*C_STRAIN_RATE_M AG(c,t)-C_R(c,t)*C_R(c,t)*C_mu*C_UDSI(c,t,TK)*C_UDSI(c,t,T K)/C_MU_T(c,t);
return source;
/* define source term in eplison equation */
DEFINE_SOURCE(TE_SOURCE, c, t, dS, eqn)
real source, Pk;
Pk=C_MU_T(c,t)*C_STRAIN_RATE_MAG(c,t)*C_STRAIN_RAT E_MAG(c,t);
dS[eqn]=0.0;
source=C1e*C_UDSI(c,t,TE)*Pk/C_UDSI(c,t,TK)-C2e*C_R(c,t)*C_UDSI(c,t,TE)*C_UDSI(c,t,TE)/C_UDSI(c,t,TK);
return source;
/* define diffusion coefficienct */
DEFINE_DIFFUSIVITY(KE_diffusivity,c,t,i)
real diff;
real mu_t;
int nscalar=i;
mu_t=C_R(c,t)*C_mu*C_UDSI(c,t,TK)*C_UDSI(c,t,TK)/C_UDSI(c,t,TE);
if (nscalar==TK)
diff= mu_t/SIG_k + C_MU_L(c,t);
else
diff = mu_t/SIG_e + C_MU_L(c,t);
return diff;
/*define turbulent viscosity */
DEFINE_TURBULENT_VISCOSITY(turbVis,c,t)
real mu_t;
return mu_t;
Turbo_hrf is offline   Reply With Quote
Old   November 26, 2015, 07:51
pakk will become famous soon enough
Fluent tries to initialize the diffusivity, and to do this it needs the values of the user defined scalars, but they are not calculated yet.
The udf that you wrote tries to read data that is not stored yet. Without getting too technical, this is an example of a 'segmentation fault'.
There are two possible solution methods:
1. Re-write your code such that if you are initializing, your code recognizes this and does not try to read undefined user defined scalars. (The preferred method if you were a professional programmer.)
2. Initialize your data without the udf, and attach the udf later. (The quick and easy solution.)
pakk is offline   Reply With Quote
Old   September 14, 2017, 07:47
Camille Bilger
kmou is on a distinguished road
I tried doing this but I still get a segmentation fault error. Could the error be linked to a non-UDF related problem then?
Thank you
kmou is offline   Reply With Quote
Old   September 14, 2017, 08:15
My answer was specific for the code that Turbo_hrf gave.
You (probably) use different code, but get the same warning.
If you want to know if the error is caused by something else than your udf, this is easy to test: don't use the udf, and see if you get the same error.
It is possible that your error has nothing to do with your udf, and that it is caused by a mistake of the Fluent programmers. But it is far more likely that it is a problem in your udf; you are probably telling Fluent to read a value that does not exist.
Without seeing your UDF, I can not help more.
Old   September 14, 2017, 09:35
Camille Bilger
Hi pakk,
thanks for getting back to me so quickly.
I did and I do get the error....which is weird because this would make sense:
I agree. I have variables which are not yet initialised in the UDF:
DEFINE_HET_RXN_RATE(char_o2,c,t,hr,mw,yi,rr,rr_t)
     Thread **pt = THREAD_SUB_THREADS(t);
     Thread *tp = pt[0];        /* gas phase or primary phase */
     Thread *ts = pt[1];        /* solid phase or secondary phase */
     real T_p = MAX(293.,C_T(c,tp));    /* primary phase temperature */
     real T_s = MAX(293.,C_T(c,ts));    /* secondary phase temperature */
     T_p = MIN(T_p,TMAX);
     T_s = MIN(T_s,TMAX);
     const real Rgas = 8.314;        /* ideal gas constant Joule/mol.K */
                    /* UNIVERSAL_GAS_CONSTANT = 8314 J/kmol.K;*/
     real p_o2 = 0.;            /* pressure in Pa = N/m^2 = kg/m.s^2 */
     real k_c, k_d;            /* coefficients related diffusion and kinetic */
     real D_p = C_PHASE_DIAMETER(c,ts); /* solid particle diameter FLUENT macro */
     const real Ac = 0.052;              /* kg/(m^2 . s . Pa^0.5) */
     const real Ec = 6.1e7;              /* J/kmol */
     real Re, Sc, Sh, urel, urelx,urely,urelz=0.;
     real Dk = C_DIFF_EFF(c,tp,index_primary) - C_MU_T(c,tp)/(0.7*C_R(c,tp));
     *rr = 0.0e0; /* reaction rate */
     C_UDMI(c, t, 20) = 0.0e0;
     C_UDMI(c, t, 21) = 0.0e0;
     if(C_VOF(c, tp) < eps_g_small && yi[INDEX_PHASE_C][INDEX_SPECIES_C] > spe_small && yi[INDEX_PHASE_O2][INDEX_SPECIES_O2] > spe_small)
         p_o2 = C_R(c,tp) * UNIVERSAL_GAS_CONSTANT * C_T(c,tp) * yi[index_primary][INDEX_SPECIES_O2] / 32.0e0; /* kg/m.s^2 */
         if(C_VOF(c, ts) <= 0.0e0)  /* for negative volume fraction from wrong calculations */
                *rr = 0.0e0;
         else
                k_c = Ac * exp( -1.0e0 * Ec / UNIVERSAL_GAS_CONSTANT / T_s ); /* kinetic coefficient */
                /* Calculation of Sherwood number and then reaction rate */
           if(Data_Valid_P())
                     urelx = C_U(c,tp) - C_U(c,ts);
                     urely = C_V(c,tp) - C_V(c,ts);
                #if RP_3D
                urelz = C_W(c,tp) - C_W(c,ts);
                #endif
                   urel = sqrt(urelx*urelx + urely*urely + urelz*urelz);  /* relative velocity*/
                      Re = urel * D_p * C_R(c,tp) / C_MU_L(c,tp);
                     Sc = C_MU_L(c,tp) / C_R(c,tp) / Dk ;
                Sh =  2. + 0.6 * pow(Re, 0.5)* pow(Sc, 0.333);
                       k_d = (Dk * mw[INDEX_PHASE_C][INDEX_SPECIES_C] * Sh ) / (T_p * UNIVERSAL_GAS_CONSTANT * D_p); /* diffusion coefficient */
            *rr = (-1.0e0 * k_c) + sqrt(k_c * k_c + 4.0*k_d*k_d*p_o2);
            *rr = *rr * ( (6.0*C_VOF(c,ts)*k_c) / (2.0*D_p*k_d));
            *rr = *rr / mw[INDEX_PHASE_C][INDEX_SPECIES_C];
                    C_UDMI(c, t, 20) = *rr;
                    C_UDMI(c, t, 21) = yi[INDEX_PHASE_C][INDEX_SPECIES_C] * volume_p(D_p/2.0) * C_R(c,ts);
But now I am using
if(Data_Valid_P())
and it still does not work. I also tried Initialising before loading the UDF but it fails to do so, it does not give me an error message it just hangs there...
fluentError: received a fatal signal (Segmentation fault). thomaszhangjing Fluent UDF and Scheme Programming 11 January 13, 2021 09:37
receive fluent received a fatal signal (Segmentation fault). chenkaiqe FLUENT 2 March 10, 2015 08:21
Fluent Error: fatal signal received (Segmentation fault) gopalkrishnan FLUENT 0 December 16, 2014 01:37
Error: received a fatal signal (Segmentation fault). Revist Fluent UDF and Scheme Programming 1 December 12, 2014 13:18
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
