UDF to extract particle positions and velocities at outlet
Like Tree1Likes
  • 1 Post By `e`
Old   February 29, 2016, 07:11
Red face UDF to extract particle positions and velocities at outlet
Anonymous
marauder is on a distinguished road
I have two individual runs where the DPM particle's velocities and positions at outlet in first run are to be used as an input DPM file injection (.inj) at the inlet of second run.
Can anybody suggest a method to extract the particle profile at the outlet surface required to create the injection file?
marauder is offline   Reply With Quote
Old   February 29, 2016, 22:58
Anonymous
any idea anyone?
Old   February 29, 2016, 23:39
`e`
`e` is on a distinguished road
Write the particle positions (P_POS) and velocities (P_VEL) to a text file called say myOutletParticles.inj and then use this file for your second run. Ensure you use the proper format for the injection file (x y z u v w...).
`e` is offline   Reply With Quote
Old   March 1, 2016, 00:15
Anonymous
Hey thanks for that, i was able to print velocities using P_VEL but I'm getting following error for P_POS in the following code, can you help?
P_POS: undeclared variable
code:
#include "udf.h"
DEFINE_DPM_OUTPUT(history,header,fp,p,t,plane)
if(header)
printf("This is a test\n");
else
if(p==NULL)
else{
printf("%10.6f %10.6f %10.6f \n",P_VEL(p)[0],P_VEL(p)[1],P_POS(p)[0]);
Old   March 1, 2016, 04:09
`e`
Are you compiling or interpreting this UDF? Compiling UDFs is generally the more stable and reliable method.
marauder likes this.
Old   March 1, 2016, 12:33
Anonymous
Thanks compiled finally after installing visual studio etc. Seems to be working!
Particle Injection induced from a UDF Peter023 Fluent UDF and Scheme Programming 3 November 26, 2018 03:55
advancing velocities and positions in pimpleDyMFoam fsaltara OpenFOAM 0 January 4, 2014 11:17
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
DPM - Particle velocities Umesh Shah FLUENT 2 April 3, 2003 12:55
