Problems in converging viscosity UDF dependent upon strain rate and temperature.
Old   March 17, 2016, 06:33
Default Problems in converging viscosity UDF dependent upon strain rate and temperature.
Alex Skerhut
alexskerhut is on a distinguished road
I am interpreting a viscosity UDF which is dependent upon temperature and strain rate. The UDF interprets fine but does not lead to convergence and starts diverging from the very start and does not run even a single iteration. My UDF is as follows:
#include<udf.h>
DEFINE_PROPERTY(cell_viscosity,c,t)
double stress = 22.22e+06;
double A = 8.86e+06;
double energy = 145000;
double R = 8.314;
double n = 3.55;
double mu_laminar,temp,strainrate,Z,D,E,F;
temp= C_T(c,t);
strainrate= C_STRAIN_RATE_MAG(c,t);
Z= strainrate*exp(energy/(R*temp));
D= pow((Z/A),(1/n));
E= pow((Z/A),(2/n));
F= pow(E+1,0.5);
mu_laminar= (stress*log(D+F))/(3*strainrate);
return mu_laminar;
A similar viscosity model named carreau dependent upon strainrate and temperature converges fine but my udf does not even start iterating. It gives the error message
#Divergence detected in AM solver: x-momentum - Increasing relaxation sweeps!
Kindly help me in this my complete project depends upon the successful implementation of the viscosity UDF.
alexskerhut is offline   Reply With Quote
Old   March 17, 2016, 07:19
pakk will become famous soon enough
Print the values to your screen.
Message("Z,D,E,F: %f,%f,%f,%f\n",Z,D,E,F);
Message("Mu: %f\n",mu_laminar);
return mu_laminar;
(If I remember the syntax correctly, otherwise check the manual.)
Then check if the values that are shown agree to what you want. If they don't, find out why not and fix your equations.
pakk is offline   Reply With Quote
fluent - udf, udf and programming, udf compile, udf eror
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Time and temperature dependent viscosity sur4j OpenFOAM 16 January 12, 2015 00:56
Temperature dependent Non-Newtonian viscosity UDF cric92 Fluent UDF and Scheme Programming 0 April 14, 2013 06:31
