"No user defined functions have been loaded"
Like Tree1Likes
  • 1 Post By SAM S
Old   March 21, 2016, 03:02
Default "No user defined functions have been loaded"
SAM S is on a distinguished road
After solving the compilation errors when I try to to hook the mass transfer source udf under phase interaction I am getting the error "No user defined functions have been loaded". What should be the mistake now? Can anyone help me please.
Thank you
SAM S is offline   Reply With Quote
Old   March 21, 2016, 03:30
pakk will become famous soon enough
Maybe you did not solve the compilation problems...
pakk is offline   Reply With Quote
Old   March 21, 2016, 03:54
Thank you for the reply pakk. Herewith I have included the message I got when I build the udf library and loaded it. Could you please have a look at it and advice me what to rectify.
> Copied e:\project/source.c to libudf\src
Copied e:\project/header.h to libudf\src
Creating user_nt.udf file for 2ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v160\fluent"\fluent16.0.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_host")# Generating ud_io1.h
source.c
# Generating udf_names.c because of makefile source.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj source.obj
Microsoft (R) Incremental Linker Version 12.00.31101.0
Copyright (C) Microsoft Corporation. All rights reserved.
Creating library libudf.lib and object libudf.exp
Creating user_nt.udf file for 2ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v160\fluent"\fluent16.0.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_node")# Generating ud_io1.h
source.c
udf_names.c
Done.
Opening library "E:\project\libudf"...
Library "E:\project\libudf\win64\2ddp_host\libudf.dll" opened
Library "E:\project\libudf\win64\2ddp_node\libudf.dll" opened
liq_gas_source
Done.
Old   March 21, 2016, 03:58
This suggests that one function is loaded: liq_gas_source.
What type is this? Did you define it with:
DEFINE_SOURCE (liq_gas_source, c, t, dS, eqn)
Old   March 21, 2016, 04:22
Yes it is been loaded but when I try to hook ( phase interaction --> mass --> mechanism --> user defined), am getting the error.
I will give the code here
#include "udf.h"
#include "math.h"
DEFINE_MASS_TRANSFER(liq_gas_source,cell,thread,fr om_index,from_species_index,to_index, to_species_index)
real m_lg;
real T_SAT = 373.15;
real vof_cutoff = 0.05;
Thread *liq = THREAD_SUB_THREAD(thread, from_index);
Thread *gas = THREAD_SUB_THREAD(thread, to_index);
m_lg = 0.0;
if ( (C_VOF(cell,thread) > vof_cutoff ) && (C_VOF(cell,thread) < (1 - vof_cutoff) ))
if ((m_lg == 0.0) && (C_T(cell,liq) >= T_SAT))
m_lg = -0.1*C_VOF(cell,liq)*C_R(cell,liq)*fabs(C_T(cell,li q)-T_SAT)/T_SAT;
if (C_T(cell, gas) <= T_SAT)
m_lg = 0.1*C_VOF(cell,gas)*C_R(cell,gas)*fabs(T_SAT-C_T(cell,gas))/T_SAT;
return (m_lg);
Old   March 21, 2016, 04:44
"In order to hook a DEFINE_MASS_TRANSFER UDF to Fluent, you must first issue the TUI command solve/set/expert and enter no at the Linearized Mass Transfer UDF? prompt."
You did that?
Old   March 21, 2016, 05:47
Thank you for your help. I solved it now
Old   April 17, 2016, 07:53
Wang Jie
qhwj1990 is on a distinguished road
I meet the same problem,could you tell me how do you solve it?
qhwj1990 is offline   Reply With Quote
Old   April 19, 2016, 01:22
In your fluent TUI, you have to type "solve/set/expert" and enter. Next give "no" for linearised mass transfer. now check if your udf is loaded.
Old   June 20, 2016, 18:09
SHUJAN
MDSHUJAN is on a distinguished road
Sam. I am in similar type of problem, and also my udf is similar to you (LEE model). Can you tell me in detail that how you hook that udf. After build, and loading , i see error that no udf is loaded, when i try to hook it.
MDSHUJAN is offline   Reply With Quote
Old   June 20, 2016, 18:31
SHUJAN
Hi. Can you say in detail, how you solve this problem? Which version of ANSYS you can using ?
Old   June 21, 2016, 02:59
I am using Ansys 16, and for that problem you need to type the command I earlier mentioned in this thread. You have to provide the answer as no when there is a question about linearized mass transfer.
wxchu84 likes this.
Old   May 29, 2023, 06:29
Tokk
Tokzhan is on a distinguished road
I have same problem. How to solve
Tokzhan is offline   Reply With Quote
Old   August 18, 2023, 01:57
Default Error: No user-defined functions of type udf-type-exchange-property have been loaded
  #14
Victoria
Shivani is on a distinguished road
I have managed to execute the UDF without any issues, but I am currently facing an error while trying to choose the heat transfer coefficient for interaction.
Error: No user-defined functions of type udf-type-exchange-property have been loaded.
Error Object: #f
Can someone help me in resolving it?
Shivani is offline   Reply With Quote
Old   August 18, 2023, 02:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
your udf is not compiled properly
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
User defined functions abhishek.iiest Fluent UDF and Scheme Programming 4 May 22, 2015 09:15
Allocating user defined memory djn FLUENT 2 April 14, 2015 10:59
user defined scalar vs species transport gvj_mech FLUENT 0 March 27, 2014 14:33
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 18:18
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
