Need help to read a TSV file with Scheme code.
Old   June 29, 2016, 16:04
Question Need help to read a TSV file with Scheme code.
Negar Saeidi
nsaeidi is on a distinguished road
Hello everybody,
I need some help to write a Scheme code that will take inputs from a TSV file at every time step of my FLUENT simulation and assign those values to OutFlow boundary conditions.
To be more clear, I want it to read first line of the TSV file at the first time step and assign each value in the line to each Outflow boundary condition. The same for second line at the second time step, until the simulation is over.
Here is a piece of code that I wrote which doesn't work:
(define n 0.0)
(with-input-from-file "doors.txt"
(define run
(lambda (flow-time)
(set! n (/ flow-time 10)) ;10 is the size of time-steps
(let iter (n list))
(let ((a b c) (string-split line #\space)))
(ti-menu-load-string (format #f "def bc outflow 6 ~a" a))
(ti-menu-load-string (format #f "def bc outflow 7 ~a" b))
(ti-menu-load-string (format #f "def bc outflow 8 ~a" c))
I'd really appreciate your comments and advices.
Regards,
nsaeidi is offline   Reply With Quote
Old   July 5, 2016, 14:15
Negar Saeidi
I have got to this point:
(define a 0.0)
(define b 0.0)
(define c 0.0)
(define RUN
"doorstatesnegar.txt"
(lambda ()
(let (line (read-line))
(if (not (eof-object? line))
(let (((a b c) (string-split line #\space)))
(newline)
And this is the error that I receive:
Error: let syntax: binding is not a list Error Object: line
Any ideas?
reading tsv files, scheme files, scheme programming
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
