diffusivity
Old   September 19, 2016, 12:10
Default diffusivity
Ribes is on a distinguished road
HI!
I wrote this code to define a different diffusivity for the air in the porous media and not porous media:
#include "udf.h"
DEFINE_DIFFUSIVITY(diffusion_coefficient,c,t,i)
if (C_POR(c,t)==1)
Diff=2.31*e5*101325/C_P(c,t)*pow(C_T(c,t)/273.15,1.81)
else
Diff=2.31*e5*101325/C_P(c,t)*pow(C_T(c,t)/273.15,1.81)*pow(C_POR(c,t),2.24)
return Diff
when I compile it gives parse error on line 3....is it because of the C_POR macro? I founded this notation in the forums..thanks for any help
Ribes is offline   Reply With Quote
Old   September 20, 2016, 04:46
Bruno Machado
Bruno Machado is on a distinguished road
Originally Posted by Ribes View Post
HI!
#include "udf.h"
if (C_POR(c,t)==1)
else
return Diff
if you dont say what error you got, we cant help you properly. at a first sight I can tell that you didnt put { and } to define the boundaries of your DEFINE_DIFFUSIVITY macro.
Bruno Machado is offline   Reply With Quote
Old   September 20, 2016, 05:38
Thanks, I added the {} but now it tells me :
line 4: structure reference not implemented
Old   September 20, 2016, 06:30
Bruno Machado
have you defined the variables you used?
Old   September 21, 2016, 04:49
Yes...I think the problem is that I need to compile the function instead to just interpret it..I'm a little confused by the difference between this proceedings(I read also in the manual but it still isn't clear to me). When I compile it I get the error:
"RPC RCX_SC_SET_ERR_MSG failed: RPC: Can't encode arguments
The UDF library you are trying to load is not compiled for 2ddp on the current platform (win64)."
I haven't any spaces in the files name..is it an error in the code or in the systems settings?
Last edited by Ribes; September 21, 2016 at 05:26. Reason: didn't write the full error
Kinematic Diffusivity - Problem with additional variable clau90 CFX 3 May 14, 2014 09:54
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 22:08
Species Diffusivity in PEMFC Simulation circle2000 FLUENT 0 September 20, 2004 22:12
Species diffusivity zhou1 FLUENT 0 November 4, 2003 17:23
