problem with UDF compile
Like Tree1Likes
  • 1 Post By Bruno Machado
Old   October 25, 2016, 01:07
Default problem with UDF compile
Tamilnadu
sridhar palla is on a distinguished road
Hello everyone,
I'm trying to compile UDF in the fluent but at the time of compiling it is showing the following error to each UDF at assigning the function everytime.
UDF 1 for n = no * exp(-(R*T/(Alpha+(beta*T))^2)*ln(p_o/p)^2)
#include "udf.h"
DEFINE_ADJUST(ads,domain)
Thread *t;
real E,A,P;
cell_t c;
thread_loop_c (t,domain)
begin_c_loop (c,t)
real tem = C_T(c,t);
P=C_P(c,t)+RP_Get_Real("operating-pressure");
E=3080+18.9*tem;
A=8.314*tem*log(1.47E9/P);
C_UDSI(c, t, ads) = 71.6*(exp(-((A*A) / (E*E)))); error is in this line
end_c_loop (c,t)
error in compiling this file is
error C2296: '*' : illegal, left operand has type 'void (*)(Domain *)'
Can anyone please help me with this?
sridhar palla is offline   Reply With Quote
Old   October 25, 2016, 05:39
Bruno Machado
Bruno Machado is on a distinguished road
have you defined the UDS? If yes, try to assign this value in DEFINE_EXECUTE_AT_END and see if it works.
Bruno Machado is offline   Reply With Quote
Old   October 25, 2016, 07:46
Tamilnadu
i don't understand the defining UDS here,
ads is the function name i'm using to define 'n' and in C_UDSI macro im assigning it.
And how to assign the value in DEFINE_EXECUTE_AT_END ?
Thank you.
Old   October 25, 2016, 08:36
Bruno Machado
Thank you.
ads is the name of the scalar you are defining, but you have not declared it. you need to declare the number/name of your scalars.
All the information I am writing is in the manual...
Old   October 26, 2016, 00:22
Tamilnadu
This is the complete UDF i'm doing for mass source term
it is (mass source term) Sm = X* d(n,t)
the first code i posted for n only
in this udf i'm adding to it calls the n every calculating Sm here
#include "udf.h"
Thread *t;
real E,A,P,ads;
cell_t c;
begin_c_loop (c,t)
E=3080+18.9*tem;
C_UDSI(c, t, ads) = 71.6*(exp(-((A*A) / (E*E)))); "error C2296 in this line"
end_c_loop (c,t)
DEFINE_ADJUST(q_ads,domain)
Thread *t;
cell_t c;
real dt,q_ads;
thread_loop_c(t,domain)
begin_c_loop (c,t)
dt=RP_Get_Real("physical-time-step");
C_UDSI(c,t,q_ads)=C_UDSI_M1(c,t,q_ads)+0.15*dt*(C_ UDSI_M1(c,t,ads)-C_UDSI_M1(c,t,q_ads)); "error C2296 in this line"
end_c_loop(c,t)
DEFINE_ADJUST(d_ads, domain)
Thread *t;
cell_t c;
real d_ads;
thread_loop_c(t, domain)
begin_c_loop(c, t)
C_UDSI(c, t, d_ads) = -0.532224*0.15*(C_UDSI(c, t, ads) - C_UDSI(c, t, q_ads)); "error C2296 in this line"
end_c_loop(c, t)
DEFINE_SOURCE(m_src,c,t,dS,eqn)
dS[eqn]=0.0;
return C_UDSI_M1(c, t, d_ads); "error C2296 in this line"
error C2296: '*' : illegal, left operand has type 'void (*)(Domain *)' this is coming in each time assigning functions.
Can you please check this once ?
Old   October 26, 2016, 04:39
Bruno Machado
#include "udf.h"
Thread *t;
real E,A,P,ads;
cell_t c;
begin_c_loop (c,t)
E=3080+18.9*tem;
end_c_loop (c,t)
Thread *t;
cell_t c;
real dt,q_ads;
begin_c_loop (c,t)
end_c_loop(c,t)
Thread *t;
cell_t c;
real d_ads;
begin_c_loop(c, t)
end_c_loop(c, t)
dS[eqn]=0.0;
As I mentioned before, you need to define ads and q_ads. Fluent defines the name of the UDS as 0,1,2... If you do not tell fluent that ads and q_ads are your UDS, he wont be able to know.
add this at the begging of you code
enum /* UDSs */
ads,
q_ads,
NUM_UDS
Old   October 26, 2016, 04:42
upeksa is on a distinguished road
#include "udf.h"
enum
ads,
q_ads,
d_ads,
DEFINE_ADJUST(define_ads,domain)
Thread *t;
real E,A,P;
cell_t c;
real tem;
begin_c_loop(c,t)
tem = C_T(c,t);
E=3080.0+18.9*tem;
A=8.314*tem*log(1.47e9/P);
C_UDSI(c,t,0) = 71.6*(exp(-((A*A) / (E*E))));
end_c_loop(c,t)
DEFINE_ADJUST(define_q_ads,domain)
Thread *t;
cell_t c;
real dt;
begin_c_loop(c,t)
end_c_loop(c,t)
DEFINE_ADJUST(define_d_ads, domain)
Thread *t;
cell_t c;
begin_c_loop(c,t)
end_c_loop(c,t)
dS[eqn]=0.0;
Here is your code, it compiles now. You had many issues, for example ads, q_ads and d_ads must be integer numbers, not real numbers. Moreover, they cannot be at the same time the name of the macro itself (I have change the name of the macro "define_ads" and so on.
Check the code, since I don't know what do you want to do and I might have made some modifications that don't work in your case.
Regards
upeksa is offline   Reply With Quote
Old   November 3, 2016, 06:08
Default error received a fatal signal (Segmentation fault)
Tamilnadu
Thank you for the reply now my UDF is compiling but while intializing the model showing below error
" received a fatal signal (Segmentation fault)"
Can you please help me with this what might be the problem ?
Old   November 3, 2016, 07:19
Bruno Machado
this usually is associated with the fact fluent is trying to obtain something is not available. Check is all your variables are properly assigned.
You can add messages to your code, so you will be able to see where it stops. use something like
Message("1");
YOUR CODE
Message("2");
alinik likes this.
Fluent 6.3.26 on Linux does not compile an UDF Entwistle Fluent UDF and Scheme Programming 1 March 4, 2014 14:49
Mesh UDF problem kornetka Fluent UDF and Scheme Programming 4 July 25, 2013 06:54
compile a udf or interpret it? ndabir Fluent UDF and Scheme Programming 1 July 14, 2012 02:49
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
