UDF Compiled
Old   January 31, 2017, 12:27
Default UDF Compiled
Varion
bbackesbruno is on a distinguished road
Hi guys,
I'm new in UDF implementing and I am having some problems when I try to couple my udf with FLUENT. Whenever I try to define my UDF using a compiled file, FLUENT returns no error, I am able to build and load my code, but when I initialize the solution it all stop working and the window closes. Does anybody have any idea of what could be causing this?
Thanks in advance
bbackesbruno is offline   Reply With Quote
Old   February 2, 2017, 11:21
pakk will become famous soon enough
It could be a problem in your UDF, but because you did not share it, it is impossible to say that.
pakk is offline   Reply With Quote
Old   February 2, 2017, 12:03
Varion
It's working now. The problem was exactly what you have mentioned.
Thanks
fluent, udf
Error: The UDF library you are trying to load is not compiled for 3ddp on the current Whitemast Fluent UDF and Scheme Programming 0 November 21, 2013 06:45
UDF compiled problem Enricodex Fluent UDF and Scheme Programming 2 August 11, 2013 17:48
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 12:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 14:32
compiled UDF bharti FLUENT 2 November 15, 2006 13:04
