UDF for output temperature
Old   August 17, 2017, 12:24
Default UDF for output temperature
mariam.sara is on a distinguished road
Hi I am attempted to use UDF to define dimensionless temperature in order to use it in post processing results I wrote it as below :
#include "udf.h"
DEFINE_ON_DEMAND(on_demand_calc)
Domain *d; /* declare domain pointer since it is not passed as an
argument to the DEFINE macro */
real th = 298.3899;
real tc = 297.6101;
real temp;
Thread *t;
cell_t c;
d = Get_Domain(1); /* Get the domain using Fluent utility */
/* Compute temperature function and store in user-defined memory*/
/*(location index 0) */
begin_c_loop(c,t)
temp = C_T(c,t);
C_UDMI(c,t,0) = (temp-tc)/(th-tc);
end_c_loop(c,t)
I interpreted it successfully but when I select execute for demand it give me the following error:
Warning: E:\\Project current year\\paper work\\output.C: line 9:
Error: received a fatal signal (Segmentation fault).
So is there problem with the UDF? any reply please?
regards,
mariam
mariam.sara is offline   Reply With Quote
Old   August 18, 2017, 06:12
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
Did you allocate memory to store the UDM? Go to "User Defined" -> "Memory" and the set "Number of User-Defined Memory Locations" to 1.
MayTheFlowBeWithYou is offline   Reply With Quote
Old   August 18, 2017, 07:21
Hi Thanks for the reply. I set the memory to 1 from the user defined menu but nothing appear at display >contours>User defined memory see pict? what the problem?
Old   August 18, 2017, 07:39
User defined memory indices start at 0. Assuming to did re-run the simulation,
You can also (in Fluent) go to File > Export > Solution Data...
The set "CFD-Post Compatible" as File Type. And choose User Memory 0 in the "Quantities list" (and whatever other things you want to store). Then click write and store in somewhere you want.
The use the CFD-Post to read that file.
Old   August 18, 2017, 08:14
I interpreted the UDF at first then change the memory to 1 then I initialize the solution and run the case after that when I view the user memory contours nothing appears to me same as the pict I sent in my previous reply?
Old   August 18, 2017, 09:42
User Memory 1 (the one you're trying to draw contours for in the picture) shouldn't even exist for your simulation. As I said, User Defined memory Indices start at 0, so you should have a User Memory 0. Can you find this or not?
Old   August 18, 2017, 11:21
Cannot find User Memory 1 ? just User Memory 0 exist and nothing appear with it? maybe my steps was wrong or my UDF not interpreted successfully? may you repeat the procedure to me step by step? Currently do I need to apply execute on demand option or not need it?
Old   August 18, 2017, 13:51
Ok, so you have your UDF exactly as you posted, it is correct.
First you allocate the User Defined Memory Location (For you UDF you only need to allocate 1 memory location for UDMI(c,t,0)).
Second, you interpret (or compile, whatever you prefer) your UDF.
Third, run the code. It is a execute on command, so go to User Defined > Execute on command... then select your code and hit "execute".
Now it should be written.
Also after viewing your first post again, I see that you use Fluent to also draw the contours. You have not selected a surface for fluent to draw them on, so it wont draw anything. You'll probably want to select "Interior_surface_body".
I hope this will work for you.
Old   August 18, 2017, 16:04
When I go to User Defined > Execute on command
it still give me the error I mentioned at my first post i.e.
Warning: E:\\Project current year\\kefayati paper\\output.C: line 9:
Old   August 19, 2017, 08:22
I assume line 9 is "real temp;", nothing seems to be wrong there at all.
What I think is going wrong now is that the thread pointer (*t) is never actually set to anything.
I will assume that you want to loop over all cells in the domain. To do this try the following code:
#include "udf.h"
real th = 298.3899;
real tc = 297.6101;
real temp;
Thread *t;
cell_t c;
thread_loop_c(t,d) /* This will loop over all threads in the domain */
begin_c_loop(c,t) /* This will loop over all cells in a thread */
temp = C_T(c,t);
end_c_loop(c,t)
Use as I described before.
UDF for Temperature Dependent Energy Source er.mkumar Fluent UDF and Scheme Programming 9 March 14, 2024 04:01
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
UDF temperature profile asal Fluent UDF and Scheme Programming 67 August 7, 2018 12:41
UDF slip and temperature jump from IFRT abir Fluent UDF and Scheme Programming 1 July 30, 2012 05:44
UDF or any approach for Bulk Temperature calculation vemps FLUENT 0 May 1, 2009 01:09
