THREAD_SUPER_THREAD macro gives parse error
Old   August 25, 2017, 00:59
Default THREAD_SUPER_THREAD macro gives parse error
Anuja Vijayan
anuarun is on a distinguished road
Hello friends,
I have written the following UDF for changing the vapour density based on mixture domain temperature. I am using a mixture model for simulating two phase flow.
While interpretation, it shows
line 51: parse error
line 52: parse error
line 53: undeclared variable rho
DEFINE_PROPERTY(Vapour_density,c,t)
Thread *tp;
tp = THREAD_SUPER_THREAD(t); /*line 51*/
real T = C_T(c,tp); /*line 52*/
real rho; /*line 53*/
rho = (0.00329*exp(0.19039*T) - 0.05762)*1000000.0;
return p_v;
I cannot find any mistake in it. Is it because I have interpreted instead of compilation (it is not likely to be so)? Any help is greatly appreciated.
anuarun is offline   Reply With Quote
Old   August 28, 2017, 01:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Originally Posted by anuarun View Post
Hello friends,
Thread *tp;
return p_v;
Try this one:
	Thread *tp;
	return p_v;
Best regards
AlexanderZ is offline   Reply With Quote
Old   August 28, 2017, 08:00
Anuja Vijayan
Hi Alexanderz,
Originally Posted by AlexanderZ View Post
Try this one:
	Thread *tp;
	return p_v;
Best regards
Thank you for your suggestion. I have tried this. It is getting interpreted without any problem.
Actually, I think there is no point in changing the density in incompressible formulation (Initially I had similar UDF for vapour pressure and density). I decided to keep it constant for the simulation. So I incorporated the suggested changes in the macro for vapour pressure as follows.
DEFINE_PROPERTY(Vapour_pressure,c,t)
Thread *tp;
real p_v; /*line 53*/
p_v = (0.00202*exp(T/4.78878) - 0.04038)*1000000.0;
return p_v;
One more point is that I do not know whether DEFINE_PROPERTY(Vapour_pressure,c,t) is internally invoked by Fluent the same way as it does for a property as density or viscosity. Or is there a macro specifically for vapour pressure? I could not find one.
Anyway, I am running my simulation with the modifications. I will post the result once it is complete.
Old   August 28, 2017, 20:51
Alexander
Hello!
I do not have experience in multiphase flows simulation. However, I believe that you should choose your UDF functions as a density material property of vapour.
Best regards
Old   August 29, 2017, 09:14
Anuja Vijayan
Hi AlexanderZ,
Try this one:
	Thread *tp;
	return p_v;
Best regards
This one is giving error, "Received signal SIGSEGV.
Fatal error"
I will try your second suggestion. I am not quite sure how it is implemented. I will check the manual and then get back to you.
parse error, thread_super_thread
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
