Macro for my equation
Old   September 14, 2017, 15:43
Default Macro for my equation
ARAVIND SRIDHARA
aravind vashista is on a distinguished road
Hii all,
i am simulating 3D supersonic flow for air and hydrogen. I want to know the mixing efficiency for the present case. The mixing efficiency is defined as follows;
∫▒((Y_f ρu)dA)/((yρu)dA)
Where
y_f={ y, y<y_s
y_s* ((1-y))⁄(1-y_s ), y>y_s
y_s is the species mass fraction and
ρ is the density
u is the velocity.
please help in finding the right macroname to define above equations. i have the basic idea of writing the code for udf, my only concern is to find the right macro to define above scalar equation.
Every UDF's are defined using DEFINE_MACRONAME(udf_name, passed-in variables) (say for example: DEFINE_PROFILE, to specify boundry conditions). I am unable to find this right Macroname.
aravind vashista is offline   Reply With Quote
Old   September 14, 2017, 23:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
ANSYS Fluent Customization Manual:
3.2.3.6. Flow Variable Macros for Cells
For each cell in domain you can easily got the value of ->
density by C_R(c,t)
velocity by C_U(c,t);C_V(c,t);C_W(c,t)
Could you explain in details, what is the problem with case, you had described.
Best regards
AlexanderZ is offline   Reply With Quote
Old   September 15, 2017, 00:44
ARAVIND SRIDHARA
Thank you Alexander, and i understood how to access Macros for Cell Flow Variables.
Sir in ANSYS FLUENT UDF's are defined using Functions which are supplied by Ansys Fluent in the name DEFINE_Macros contained within the header udf.h header (example: DEFINE_PROFILE, which helps in giving user defined boundary conditions (say parabolic inlet velocity profile)). In my case i am unable to find right Macroname to right my equation. please help me in finding correct Macroname (DEFINE_MACRONAME(udf_name, passed-in variables)).
Thank you
Old   September 15, 2017, 01:45
Alexander
Thank you
So first of all you should read ANSYS Fluent Customization Manual
In few words, there are several ways, how you can execute UDF functions:
1. DEFINE_ON_DEMAND function is executed once you manually click execute on demand in GUI of Fluent. In tutorials there is an example 2.2.9.DEFINE_ON_DEMAND
2. DEFINE_ADJUST executes at every iteration and is called at the beginning of every iteration before transport equations are solved. So you should put your functions inside this adjust_function body. See 2.2.1.DEFINE_ADJUST
3. DEFINE_EXECUTE_AT_END is executed at the end of an iteration in
a steady-state run, or at the end of a time step in a transient run. See 2.2.3.DEFINE_EXECUTE_AT_END
Depends on your algorithm you may choose one of this macros and put your functions inside.
Read tutorial, there are good enough example
Best regards
Old   September 15, 2017, 02:12
Smile
ARAVIND SRIDHARA
Best regards
Thank you Alexander
i will go through the manual and try to implement my code based on ur suggestions.
Old   May 21, 2023, 23:24
wang kai feng
wkf111222 is on a distinguished road
Thank you Alexander
hello sir, have you solved your problem? I have to calculate the mixing efficiency now. And would you kindly share your code with me?
wkf111222 is offline   Reply With Quote
define macro, udf's
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 13:15
Non-linearity Pressure Equation -- PISO algorithm gdeneyer OpenFOAM Programming & Development 1 August 23, 2012 05:19
error message cuteapathy CFX 14 March 20, 2012 06:45
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
