UDF Changing Rotational Velocity
Old   September 18, 2017, 10:36
Default UDF Changing Rotational Velocity
Darma Yuda
sdarmayuda is on a distinguished road
I'm quite new to this Forum and this Software. I'm trying to simulate an Fluid Coupling (Hydraulic Coupling) using ANSYS Fluent r17.2 (Academic Ver.). I want to give a Torque instead of a constant rotational velocity as my input. Therefore, it looks like I have to write an UDF File for a changing rotational velocity (ramp) in respect of time. And until certain rotational velocity, it will rotate constantly. I have found a similar code for this case and tried to modify the code.
Here it is:
#include "udf.h"
#define omega_a 0.001 /* starting omega */
#define omega_b 7500 /* final omega */
#define delta_omega 0.1 /* incremental omega */
#define Niter 10 /* iteration update interval */
DEFINE_ADJUST (myadjust,domain)
int zoneID;
int iter= (nres==0)?(1):((int)count2[nres-1]);
float omega;
Thread *tc;
zoneID = 2;
tc = Lookup_Thread(domain,zoneID);
if ((iter%Niter)==0)
omega = omega_a + (iter/Niter)*delta_omega;
if (omega > omega_b)
{omega = omega_b;}
THREAD_VAR(tc).fluid.omega = omega;
Message("At iter=%d - update omega to %fn",iter,omega);
When I try to interpret the c file in Fluent, it always gives me an Error: ''structure reference not implemented''. Can anyone tell me what's wrong with my udf file? Thank you very much for reading. Any help would be much appreciated.
Best regards,
Darma
sdarmayuda is offline   Reply With Quote
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
Help with UDF to calculate the bubble velocity for 2 phase gas enass massoud Fluent UDF and Scheme Programming 0 October 18, 2016 06:11
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
SOS!! Velocity UDF prashantthaker208 FLUENT 0 April 2, 2014 10:16
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
