How to print a message only once with printf in a UDF |
September 23, 2017, 10:08 |
Astio Lamar
Rep Power: 14 |
Hello all,
I want to print a variable in a UDF hooked to a BC in my case. However, in each iteration, the message printed several times: Code:
BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] BC Pressure: -1.19 [Pa] Any idea how can I call "printf" only once, no matter how many time hooked UDF to the BC called? Thanks. |
September 25, 2017, 21:41 |
#2 | |
Rep Power: 17 |
if(f==0) printf(xxxxxxx); |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
UDF message error (SEGMENTATION VIOLATION" C_H_G | louiza | FLUENT | 0 | July 16, 2009 04:38 |
Parse Error Message While interpreting UDF in FLUENT | dhimans | Fluent UDF and Scheme Programming | 1 | July 10, 2009 06:29 |
error message when compiling the udf | brusly | FLUENT | 6 | October 6, 2006 04:30 |
