Trouble with print to file when using Fluent in a cluster |
October 4, 2017, 12:26 |
Akshay Gopan
I have a cylinder in cross flow and I am injecting particles to look at the impact rate and other particle properties at impact to the cylinder. I am trying to print the data to file when using DEFINE_DPM_EROSION. The normal serial code works fine and I can get all the data, but when I try to parallelize nothing prints using the same serial code (fprintf). I tried using par_fprintf in parallel and the same problem - the file is created but nothing prints to file. I also tried using DEFINE_DPM_OUTPUT by setting up a P_USER_REAL value in the DEFINE_DPM_EROSION and then if P_USER_REAL is the specified value it still doesnt print using par_fprintf. Any help would be much appreciated. Regards Akshay |
par_fprintf, udf dpm |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
