ERROR CCL parser failed with message: Perl Syntax errors detected: Can't use an undef |
October 6, 2017, 10:17 |
vivekanand
Rep Power: 12 |
Hello everyone! I am trying to play a session file to create planes and polylines and thereby to extract required data using the code mentioned below. When I am trying to play the .cse file in CFD-POST the following error is displayed.
"ERROR CCL parser failed with message: Perl Syntax errors detected: Can't use an undefined value as a symbol reference at (eval 183) line 6." Any help regarding this is deeply appreciated. Please do respond. This is the code in the session file: #Post-processing macro #set results file name !my $outfile ='Nu_ConstwallQ_Bao1.xls'; !$pi = atan2(1,1)*4; !$tiny = 1.0E-8; #Set number of planes !$nplanes = 100; !open FH, "> $outfile" or die $!; !print $FH " -------------------------------------------------\n"; !print $FH "Heat transfer along the duct length \n"; !print $FH "Results file used is $resname \n"; !print $FH " Axial length \t QwallCFX \t TWall \t Tbulk \t HTC \n"; !print $FH " ------------------------------------------------\n"; #set some basic geometry locations !$l=0.02; !$d= 2.0E-3; # !$pathlen = $l; !$spacing = $pathlen/($nplanes -1); #Start of main loop ! $i = 1; ! $im = $i -1; while($i<=$nplanes){ !$clen = ($i-1)*$spacing; ! $px = $clen; ! $py = 0.0; ! $pz = 0.0; ! $nx = $pz+0.01; ! $ny = 0.0; ! $nz = 0.0; PLANE:Plane 1 Apply Instancing Transform = On Apply Texture = Off Blend Texture = On Bound Radius = 0.02 [m] Colour = 0.75, 0.75, 0.75 Colour Map = Default Colour Map Colour Mode = Constant Colour Scale = Linear Colour Variable = X Colour Variable Boundary Values = Hybrid Culling Mode = No Culling Direction 1 Bound = 1.0 [m] Direction 1 Orientation = 0 [degree] Direction 1 Points = 10 Direction 2 Bound = 1.0 [m] Direction 2 Points = 10 Domain List = /DOMAIN GROUP:All Domains Draw Faces = On Draw Lines = Off Instancing Transform = /DEFAULT INSTANCE TRANSFORMefault Transform Invert Plane Bound = Off Lighting = On Line Colour = 0, 0, 0 Line Colour Mode = Default Line Width = 1 Max = 0.0 [m] Min = 0.0 [m] Normal = $nx, $ny, $nz Option = Point and Normal Plane Bound = Circular Plane Type = Slice Point = $px [m], $py [m], $pz [m] Point 1 = 0 [m], 0 [m], 0 [m] Point 2 = 1 [m], 0 [m], 0 [m] Point 3 = 0 [m], 1 [m], 0 [m] Range = Global Render Edge Angle = 0 [degree] Specular Lighting = On Surface Drawing = Smooth Shading Texture Angle = 0 Texture Direction = 0 , 1 , 0 Texture File = Texture Material = Metal Texture Position = 0 , 0 Texture Scale = 1 Texture Type = Predefined Tile Texture = Off Transform Texture = Off Transparency = 0.0 X = 0.0 [m] Y = 0.0 [m] Z = 0.0 [m] OBJECT VIEW TRANSFORM: Apply Reflection = Off Apply Rotation = Off Apply Scale = Off Apply Translation = Off Principal Axis = Z Reflection Plane Option = XY Plane Rotation Angle = 0.0 [degree] Rotation Axis From = 0 [m], 0 [m], 0 [m] Rotation Axis To = 0 [m], 0 [m], 0 [m] Rotation Axis Type = Principal Axis Scale Vector = 1 , 1 , 1 Translation Vector = 0 [m], 0 [m], 0 [m] X = 0.0 [m] Y = 0.0 [m] Z = 0.0 [m] END END POLYLINE:Polyline 1 Apply Instancing Transform = On Boundary List = top_wall contact_region trg Colour = 0, 1, 0 Colour Map = Default Colour Map Colour Mode = Constant Colour Scale = Linear Colour Variable = X Colour Variable Boundary Values = Hybrid Contour Level = 1 Domain List = /DOMAIN GROUP:All Domains Input File = Instancing Transform = /DEFAULT INSTANCE TRANSFORMefault Transform Line Width = 2 Location = /PLANE:Plane 1 Max = 0.0 [m] Min = 0.0 [m] Option = Boundary Intersection Range = Global OBJECT VIEW TRANSFORM: Apply Reflection = Off Apply Rotation = Off Apply Scale = Off Apply Translation = Off Principal Axis = Z Reflection Plane Option = XY Plane Rotation Angle = 0.0 [degree] Rotation Axis From = 0 [m], 0 [m], 0 [m] Rotation Axis To = 0 [m], 0 [m], 0 [m] Rotation Axis Type = Principal Axis Scale Vector = 1 , 1 , 1 Translation Vector = 0 [m], 0 [m], 0 [m] X = 0.0 [m] Y = 0.0 [m] Z = 0.0 [m] END END # Sending visibility action from ViewUtilities >show /POLYLINE:Polyline 1, view=/VIEW:View 1 >show /PLANE:Plane 1, view=/VIEW:View 1 LIBRARY: CEL: EXPRESSIONS: CpT = Specific Heat Capacity At Constant Pressure*Temperature END END END EXPRESSION EVALUATOR: Evaluated Expression = CpT END > forceupdate EXPRESSION EVALUATOR USER SCALAR VARIABLE: Variable 1 Boundary Values = Conservative Calculate Global Range = Off Expression = CpT Recipe = Expression Variable to Copy = Water.Density Variable to Gradient = Water.Density END !$Qtot=massFlowInt("CpT","Plane 1"); !$mCptot=massFlowInt("Specific Heat Capacity At Constant Pressure","Plane 1"); !$Tbulk=$Qtot/$mCptot; !$qwall=lengthAve("Wall Heat Flux","Polyline 1"); !$Twall=lengthAve("Temperature","Polyline 1"); !$h=$qwall/($Twall-$Tbulk); !print $FH " %6.3e\t %9.3e \t %9.3e \t%9.3e \t %9.3e \n" , $clen,$qwall,$Twall,$Tbulk,$h; !$i =$i+1; } !close $FH; |
October 6, 2017, 11:32 |
vivekanand
Rep Power: 12 |
Somebody please give ur valuable suggestions on this code.....m in a needful situation
October 9, 2017, 09:13 |
KirMaks
Rep Power: 9 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
DeardorffDiffStress turbulence model | Zuixy | OpenFOAM Running, Solving & CFD | 0 | November 14, 2011 08:44 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
