Move two zones at the same time, like a single unit |
September 4, 2018, 07:17 |
South Yorkshire
Rep Power: 8 |
I am trying to move two mesh zones at the same time per time step. I used the DEFINE_CG_MOTION, which moves a zone as a rigid body (no internal deformation), and I prescribed a sinusoidal velocity to move both mesh zones. Here is my code: Code:
#include "udf.h" #include "mem.h" static real vy = 0.0; DEFINE_CG_MOTION(rigid,dt,vel,omega,time,dtime) { /*Define variables*/ real cg[3], vcg[3]; int i; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); Thread *thread; Domain *d = Get_Domain(1); face_t f; thread = Lookup_Thread(d,zoneID); real ctime = RP_Get_Real("flow-time"); for (i=0;i<3;i++) { cg[i]=DT_CG(dt)[i]; vcg[i] = DT_VEL_CG(dt)[i]; } vy = 0.1*sin(31.41*ctime); vel[0] = 0.0; vel[1] = vy; } DEFINE_CG_MOTION(follower,fdt,fvel,fomega,time,dtime) { /*Define variables*/ NV_S(fvel, =, 0.0); NV_S(fomega, =, 0.0); real fcg[3], fvcg[3]; real fctime = RP_Get_Real("flow-time"); int i; Thread *thread; Domain *d = Get_Domain(1); thread = DT_THREAD(fdt); for (i=0;i<3;i++) { fcg[i]=DT_CG(fdt)[i]; fvcg[i] = DT_VEL_CG(fdt)[i]; } fvel[0] = 0.0; fvel[1] = vy; } time - vel_rigid - vel_follower 0.0000 - 0.00000 - 0.00000 0.0010 - 0.00314 - 0.00000 0.0020 - 0.00628 - 0.00314 0.0020 - 0.01253 - 0.00628 ... etc As you can see, there is a delay in the "follower" velocity compared to the "rigid" one. Thus, both zones are not moving as a block. Any ideas / suggestions on how to move both zones at the same time? Thank you, |
September 4, 2018, 09:28 |
You use the static variable to transport information between functions but how could you be sure that "follower" is actually called after "rigid"? You need to assign the variable upon first call at each time step. A conceptual code looks like:
int cur_time_step = -1; func_rigid() { if (cur_time_step < N_TIME) { cur_time_step = N_TIME;vy = ...} vel[1] = vy; } func_follower() { if (cur_time_step < N_TIME) { cur_time_step = N_TIME;vy = ...} vel[1] = vy; } |
September 5, 2018, 04:56 |
#3 | |
South Yorkshire
Rep Power: 8 |
delay, udf |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
