How to inject DPM particles using DEFINE_EXECUTE_AT_END(name) ? |
September 3, 2013, 20:53 |
Dear all,
I'm using DEFINE_EXECUTE_AT_END(name) to calculate the mass to be injected. I'm performing the calculations in each time and on each cell. I need to inject solid particles at each end of calculation if the mass resulted from this calculations is higher than 0. This is my code: ======================================== #include "udf.h" DEFINE_EXECUTE_AT_END(injection_1) { Domain *d; Thread *t; cell_t c; float mass_to_inject; real centroid_cell[ND_ND]; /* to capture centroid coordinates of the cell */ d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { mass_to_inject = ...; /* some calculations are made here */ if(mass_to_inject > 0) { C_CENTROID(centroid_cell,c,t) /* captures centroid coordinates of current cell */ /* I need to inject the mass of solid particles (or equivalent flow rate): diameter: 1 mm; temperature: 373.15 K; velocity: 0.1 m (only X direction); density: 1500 kg/m³; position: X = centroid_cell[0], Y = centroid_cell[1], Z = centroid_cell[2] */ } } end_c_loop(c,t) } } ============================================ Muchas gracias!!! |
October 30, 2017, 13:20 |
Pengze Yang
Have you by any chances got the solution? I run into similar problem.
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 19:27 |
Injection of specific number of particles in DPM | DH | FLUENT | 12 | March 16, 2016 21:04 |
Fluent DPM deleting particles during iteration | civilcfd | FLUENT | 0 | August 7, 2013 11:53 |
DPM for steady flow with unsteady particles tracking | yahya | FLUENT | 0 | March 28, 2013 13:28 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
