udf not compiling
Like Tree1Likes
  • 1 Post By mamad7192
Old   October 2, 2017, 10:55
Default udf not compiling
mamad7192 is on a distinguished road
hello guys,
i am trying to simulate missile silo launch in fluent and i get errors while trying to compile the udf, i used both 6.3.26 and fluent 18 64bits. this is the error for 6.3.26 and sth similar in v18
Deleted old libudf\ntx86\2ddp\libudf.dll
1 file(s) copied.
(system "copy c:\fluent.inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2ddp")()
silo.c
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2143: syntax error : missing '{' before ':'
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
i used my v18 to compile other udfs and it works fine so i think its not a vs issue.
anybody can help me?
thanks a lot
here is the udf
http://cae-club.ru/sites/default/fil...es/2322/silo.c
Светлана likes this.
mamad7192 is offline   Reply With Quote
Old   October 3, 2017, 05:31
pakk will become famous soon enough
The indicated problem is in not in your UDF but in the code included with Fluent. So this suggests it is a configuration issue.
pakk is offline   Reply With Quote
Old   October 3, 2017, 11:00
do you have any suggestions?
Old   January 15, 2018, 21:54
sajjad ghahari
sajjad.gh is on a distinguished road
hello, any solution?
if the answer is yes, could you plz share it with me?
sajjad.gh is offline   Reply With Quote
Old   January 16, 2018, 10:00
i think you should use a 32bit windows&fluent,although i did not try anymore.
Old   January 23, 2018, 13:12
Wael
saadyw is on a distinguished road
Hi
I don't know a lot about udf. However, I know that for compiling a udf, you should have Microsoft visual studio installed on your computer (complete setup). you can check the appropriate version of visual studio according to your fluent version. I mean, for fluent 16 and 17.1, visual studio 2012 works with me. May be earlier versions of visual studio work with earlier fluent versions as visual studio 2008 and 2010
saadyw is offline   Reply With Quote
Old   January 25, 2018, 10:52
Default 32 bit or 64 bit
mengtangli
Hakuna_lee is on a distinguished road
ntx86 means 32 bit. But you are using a 64 bit machine. Make sure you use the correct compiler.
Hakuna_lee is offline   Reply With Quote
Old   January 25, 2018, 10:56
Default suggestion
mengtangli
I guess if it were me, i would install Fluent 180+ and Visual Studio 2017. Use x64 VS2017 cross tool command prompt to open Fluent (remember set your path correctly), which will compile your UDF correctly.
fluent udf error while compiling: unknown type name __locale_t aditya.pandare Fluent UDF and Scheme Programming 3 April 12, 2014 14:52
ERROR in compiling UDF stefanos Fluent UDF and Scheme Programming 1 April 25, 2012 07:37
Problem with compiling the UDF raghu mohan Fluent UDF and Scheme Programming 10 December 16, 2011 23:34
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
