Diffusivity UDF in Fluent
Old   April 4, 2018, 19:16
Default Diffusivity UDF in Fluent
Max
max.kozak is on a distinguished road
I am using the Eulerian multiphase model to simulate particle flow in water. I am attempting to hook a diffusivity UDF to the mixture (code includes diffusion of the particle into the water). However, I seem to have some misunderstanding as to the setup.
I have selected for there to be one User-Defined Scalar. Next, I am compiling my UDF and loading into fluent. After that, I open up Create/Edit Materials panel and go to the UDS Diffusivity section. I am then selecting 'User-Defined' and attaching the UDF that I compiled.
After running my simulation, it seems that the UDF is not applied correctly. My UDS-0, which will hopefully track the diffusion of particles, just has a residual and value of zero, so I know that I am doing something incorrectly in this process.
Does anyone know what I am doing wrong in my setup, such that my code is not actually being applied? This is my first time using a UDF, so any help would be greatly appreciated!
max.kozak is offline   Reply With Quote
fluent, user defined function, user defined scalar
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
UDF diffusivity: problem with contour Lilly Fluent UDF and Scheme Programming 0 August 4, 2014 03:28
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 08:39
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
