June 12, 2018, 09:10 |
Problem using UDF for velocity inlet
Rep Power: 7 |
Hey,
i've real big problem using an UDF for velocity inlet and can't solve it. It's a Mesh over an Airfoil created with ANSYS ICEM 15.0. When i load the Mesh into FLUENT 15.0 everything is fine, no errors. Hybrid Initialisation is well without using the UDF, so no Errors without using the UDF. But when i want to implement the UDF and press Hybrid Initialisation, FLUENT says this: Error: %prf-set-var: invalid flonum Error Object: -1.#ind I can't figure out, where the problem is. Also never heard this error before and searching via google wasn't succesfull. So maybe someone coul help me? Here my defined UDF: #include "udf.h" #define c_max 30.88 // unit m/s #define delta 0.04 DEFINE_PROFILE(inlet_velocity, t, i) { real x[3]; real y; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); y = x[2]; if(x[2] <delta) F_PROFILE(f,t,i) = c_max * pow(x[2]/delta, 0.2); else F_PROFILE(f,t,i) = c_max; } end_f_loop(f,t) } I appreciate every kind of help. Best regards |
UDF problem- time dependent temperature at inlet | kaeran | FLUENT | 1 | June 16, 2015 21:48 |
Open channel (inlet problem) | burak_ekmekci | Main CFD Forum | 0 | December 22, 2014 07:45 |
UDF profile: Fluent method for coupling inlet and outlet | I-mech | Fluent UDF and Scheme Programming | 0 | May 10, 2014 10:36 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
UDF 3D inlet b.c. problem | Andrew | FLUENT | 4 | May 25, 2004 04:24 |
