DEFINE_PROFILE ---- SIGSEGV error - Multiphase
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   October 19, 2020, 12:14
Default DEFINE_PROFILE ---- SIGSEGV error - Multiphase
ssa
ssa_cfd is on a distinguished road
Hi all,
I am new to UDF programming and I am doing a UDF for heat transfer coefficient in multiphase simulation. The code compiles good, but produces a SIGSEGV error on execution.
#include "udf.h"
DEFINE_PROFILE(heat_gas_wall,t,i)
  Message0("TEst 00000000000");
  /*face thread*/
Thread *ti = THREAD_SUB_THREAD(t,0);
Thread *tj = THREAD_SUB_THREAD(t,1);
/*cell thread*/
Thread *tci = THREAD_T0(ti);
Thread *tcj = THREAD_T0(tj);
cell_t c;
face_t f;
Message0("TEst 0");
real v_x=0., v_y=0., v_z=0.;
real vel;
v_x = C_U(c,tcj) - C_U(c,tci);
v_y = C_V(c,tcj) - C_V(c,tci);
v_z = C_W(c,tcj) - C_W(c,tci);
vel = sqrt(v_x*v_x + v_y*v_y + v_z*v_z);
/*NV_DD(v,=,C_U(c,tcj),C_V(c,tcj),C_W(c,tcj),-,C_U(c,tci),C_V(c,tci),C_W(c,tci));
vel = NV_MAG(v);*/
real beta = 90;
real D=1;
/*dia of kiln*/
Message0("TEst 0.5");
real De = 0.5*D*(2*M_PI-beta+sin(beta*M_PI/180))/(M_PI-beta/2-sin((beta*M_PI/180)/2));
Message0("TEst 0.6");
real Re = RE_NUMBER(C_R(c,tci),vel,De,C_MU_L(c,tci));
Message0("TEst 0.7");
real kg = 1;
/*C_K_L(c,tci);*/
real omega=0.1;
Message0("TEst 1");
/*real xc = 0.01*0.1;*/
/*particle dia * experiment constant*/
/*real kb=C_K_L(c,tcj);*/
/*thermal conductivity of bed*/
Message0("TEst 2");
real pb=1;
/*C_R(c,tcj);*/
/*density of bed*/
Message0("TEst 3");
/*real cp=C_CP(c,tcj);*/
/*heat capacity of bed*/
real Rew = pow(De,2)*omega*pb/C_MU_L(c,tci);
Message0("TEst 4");
FILE *fp, *val;
fp = fopen("htc_gas_wall.txt","a+");
val = fopen("htc_val.txt","a+");
begin_f_loop(f,t)
fprintf(val, "%f,%f,%f,%f\n", Re, Rew,kg,De);
fprintf(fp, "%f\n", 1.54*pow(Re,0.575)*pow(Rew,-0.292)*kg/De);
/*F_PROFILE(f,ti,i) = 1.54*pow(Re,0.575)*pow(Rew,-0.292)*kg/De; */
/*F_PROFILE(f,tj,i) = pow(xc/kg+pow(2*sqrt(kb*pb*cp/(M_PI*tc)),-1),-1); */
end_f_loop(f,t)
Message0("TEst 5");
fclose(val);
fclose(fp);
And the output from the files are
htc_gas_wall.txt
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
31.066258
htc_val.txt
29261.040588,5488.875738,1.000000,0.971641
The error message from fluent is attached as image. I thought the C_R, C_U, C_K_L such macros are creating this error. But even after setting those values to 1, produces the same error.
How to solve this error.?
Thanks,
Senthil.
ssa_cfd is offline   Reply With Quote
Old   October 19, 2020, 15:19
pakk will become famous soon enough
You tell Fluent that c is a Cell, but you don't say which cell. And then you ask fluent to use the velocity on that unspecified cell. That gives problems.
It looks like you want to use the flow in the cell closest to the wall to calculate the Reynolds number, as input for the heat transfer. I forgot the physical equations, but is this what you need? I would find one of two things more logical : take the overall Reynolds number (with average velocity) or take the velocity at the wall (if you have wall slip).
So I can see in which lines your code breaks, but I don't know how to fix it because I don't know which equations you are trying to implement.
pakk is offline   Reply With Quote
Old   October 20, 2020, 03:31
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in addition to Pakk,
you should put the "computation" part of your code inside the loop of face
and define adjusted cell of each face, using F_C0 macro (and you are using thread_t0, which is thread of adjusted to face cell)
if you run in parallel, be careful with writing to file part. You should write to file from host
read ansys fluent customization manual for details
pawan_kmr likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 20, 2020, 09:25
ssa
Thanks for your comments.
My problem is I am modelling a heat transfer coefficients for multiphase h(gas-wall) and h(solid-wall). So I choose DEFINE_PROFILE and wanted to add both coefficients in the same UDF. Because, I am able to select only one UDF in the boundary conditions.
Simplified equations for heat transfer coefficients are
h(gas-wall) = 1.54*Re*k/D
and
h(solid-wall) = D/k + [2 * sqrt(k * rho * cp / pi)]^(-1)
So I got the sub threads from the mixture thread. Get the values from the adjacent cell and calculate the heat transfer coefficient. Because the velocity at the wall is zero.
After your comments., I simplified the code and executed. When I execute with just mixture level threads, the UDF is working and when I use the sub_threads for the phase, It produces SIGSEGV error.
Simplified UDF:
#include "udf.h"
DEFINE_PROFILE(heat_test,t,i)
  face_t f;
 cell_t c = F_C0(f,t);
real D = 1;
real beta = 90;
real vel;
v_x = F_U(f,t);
v_y = F_V(f,t);
v_z = F_W(f,t);
real Re = vel;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = 1.54*Re/De;
end_f_loop(f,t)
When I use F_U(f,ti) it crashes and when I use F_U(f,t) it works.!
Thanks,
Senthil.
Old   October 20, 2020, 09:50
In this code, you use f before you tell fluent which face it is.
Put your begin_f_loop earlier in your code, before you use f for the first time.
Old   October 20, 2020, 11:05
ssa
#include "udf.h"
  face_t f;
real D = 1;
real beta = 90;
real vel;
begin_f_loop(f,t)
v_x = F_U(f,ti);
v_y = F_V(f,ti);
v_z = F_W(f,ti);
real Re = vel;
end_f_loop(f,t)
Is this correct now.? I don't get any warnings or errors during compilation.
But the same SIGSEGV error on execution with F_U(f,ti) and works fine with F_U(f,t).
Thanks,
Senthil.
Node 0: Process 15088: Received signal SIGSEGV. hasib61 FLUENT 7 September 4, 2022 01:25
SIGSEGV Memory Access Exeption when Exporting Files using 'Update' JamesPermain STAR-CCM+ 0 April 22, 2020 10:50
Process 10300: Received signal SIGSEGV metaliat93 FLUENT 2 January 28, 2020 00:53
error: Received signal SIGSEGV ianziti92 Fluent UDF and Scheme Programming 2 December 5, 2018 16:25
define_wall_functions density and dynamic viscosity Ionut G Fluent UDF and Scheme Programming 3 March 15, 2017 10:10
