6DOF angular acceleration
Old   June 23, 2016, 10:41
Default 6DOF angular acceleration
ERMACORA Florian
flo90000 is on a distinguished road
Hello
I want to simulate the movement of a valve with the 6DOF solver. This is my code:
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(Clapet, prop, dt, time, dtime)
	prop[SDOF_MASS]=1.067e-7;
	prop[SDOF_IZZ]=5.33e-11;
	prop[SDOF_ZERO_TRANS_X]=TRUE;
	prop[SDOF_ZERO_TRANS_Y]=TRUE;
	prop[SDOF_ZERO_TRANS_Z]=TRUE;
	prop[SDOF_ZERO_ROT_X]=TRUE;
	prop[SDOF_ZERO_ROT_Y]=TRUE;
	prop[SDOF_ZERO_ROT_Z]=FALSE;
	prop[SDOF_LOAD_M_Z]=-9.81*0.0108*sin(DT_THETA(dt)[2])*0.0108;
	Message("\n 2d : Updated 6DOF properties DT_THETA_Z:%e, Mz:%e, Mass%e\n", DT_THETA(dt)[2], prop[SDOF_LOAD_M_Z], prop [SDOF_MASS]);
#include "udf.h"
DEFINE_SOURCE(xmom_source,c,t,dS,eqn)
	static real pos[ND_ND];
	static real con, source, x, y;
	static real X_MIN, X_MAX, Y_MIN, Y_MAX, C2;
	static int i;
	static Domain *domain;
	C_CENTROID(pos,c,t);
	x=pos[0];
	y=pos[1];
	X_MIN=1e-3;
	X_MAX=1.16e-3;
	Y_MIN=11e-3;
	Y_MAX=0.01082;
	C2=50000.0;
	i=0;
	if(x>X_MIN) i++;
	if(x<X_MAX) i++;
	if(y>Y_MIN) i++;
	if(y<Y_MAX) i++;
	if(i==4)
		con=C2*0.5*C_R(c,t);
		source=-con*fabs(C_U(c,t))*C_U(c,t);
		dS[eqn]=-2.0*con*fabs(C_U(c,t));
	else
		 source=0.0;
	C_UDMI(c,t,0)=source;
	return source;
DEFINE_SOURCE(ymom_source,c,t,dS,eqn)
	static int i;
	x=pos[0];
	y=pos[1];
	X_MIN=1e-3;
	X_MAX=1.16e-3;
	Y_MIN=0.01082;
	Y_MAX=0.011;
	C2=50000.0;
	i=0;
	if(x>X_MIN)i++;
	if(x<X_MAX)i++;
	if(y>Y_MIN)i++;
	if(y<Y_MAX)i++;
	if(i==4)
		source=-con*fabs(C_V(c,t))*C_V(c,t);
		dS[eqn]=-2.0*con*fabs(C_V(c,t));
	else
		 source=0.0;
	return source;
I add enough UDM location and don't have some problems during the compilation. And I have this error:
Info: 6DOF: can't compute angular acceleration.
Check moments/products of inertia.
Updating mesh at time level N...
Warning: multiple subdivision required on zone 8. Subdivide using Constant Ratio.
Error: received a fatal signal (Segmentation fault).
After some research I found this solution to decrease the limit of moments of inertia but it doesn't work
(rpsetvar 'dynamesh/sdof/minimum-cutoff-moments 1e-50)
http://www.cfd-online.com/Forums/flu...eleration.html
So I want to know if there are other possibilities and which or/and where is my fault
Thanks for your help
flo90000 is offline   Reply With Quote
Old   April 29, 2019, 10:54
Marcin
destroy is on a distinguished road
Hey, did you solve your problem?
destroy is offline   Reply With Quote
6DOF: can't compute angular acceleration laurentb FLUENT 7 July 26, 2019 12:54
angular acceleration sma_mort FLUENT 0 March 19, 2013 03:31
angular acceleration sma_mort Main CFD Forum 0 March 19, 2013 03:27
Angular Acceleration in Fluent? harikrishnan_k FLUENT 1 December 27, 2012 01:27
How to define angular acceleration Randre Fluent UDF and Scheme Programming 0 April 20, 2010 13:21
