February 12, 2019, 05:15 |
Conjugate Heat Transfer
Mohamed Mousa
Rep Power: 9 |
Dear all,
I have 2 regions (fluid and solid), and I am trying to perform conjugate heat transfer calculations between them. In that process, I need to use a UDF to map (or exchange) the data from the wall of the fluid region to the wall of the solid region. Is there a function defined in udf.h can perform that easily? if not, how can I write a function to do so. Thanks in advance. |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Conjugate Heat Transfer | Gowrav | FLUENT | 0 | October 10, 2018 05:55 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 13:01 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
VOF with conjugate heat transfer | vs138 | Fluent Multiphase | 1 | November 12, 2014 08:52 |
