dynamic mesh velocity specified for each face |
February 13, 2019, 12:17 |
bagh fay
Rep Power: 9 |
under DEFINE_CG_MOTION
i loop through the faces trying to give each face a specific velocity so the wall faces will move diffrently but after compiling and run the case i always get the wall to move at fixed velocity any advice how to correct the UDF so each face moves diffrently begin_f_loop(f,t) { i = i++; vel[1]= i*dtime; } end_f_loop(f,t) regards |
February 13, 2019, 23:43 |
Alexander
Rep Power: 34 |
is it possible, what do you think?
take a list of paper and move its part with different velocities best regards |
February 14, 2019, 02:33 |
bagh fay
Rep Power: 9 |
dear Alexander
thanks for your reply i am new in using UDF as well as in working with dynamic mesh however for my basic understanding the answer is yes otherways how can we model heart movement or expanding membranes for example i would like if you advise me how this kind of moving walls can be modeled and where i can find similar examples thanks |
dynamic mesh |
[simpleFoam] Floating point exception | seuchsy | OpenFOAM Running, Solving & CFD | 3 | November 3, 2016 09:29 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
