February 24, 2019, 00:56 |
Partition error
dhdh89
Rep Power: 7 |
I am developing a UDF that stores the UDM by calculating information from the membrane.
If I use serial mode, I can calculate it. However, if I use parallel (56 cores), the calculation value will be strange along the boundary of the partition as shown in the figure. Is there a way? Thank you in advance. |
February 24, 2019, 15:08 |
Rep Power: 26 |
It is very difficult to make a suggestion for how you can improve your code, if you don't show your code.
February 24, 2019, 21:50 |
Alexander
Rep Power: 34 |
switch off Node Values in contours options
if you are not sure about your code, put it here best regards |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
