February 26, 2019, 00:17 |
Nanofluid udf
HD
Hello all,
I am trying to create a UDF for the first time for AL2O3 nanofluid. What are the parameters I need to define in UDF? I want to give properties of nanofluids via UDF. Also please send me any reference UDF for nanofluids if possible. Thank You! |
February 26, 2019, 03:51 |
Alexander
Rep Power: 34 |
what is the difference in material properties between nanofluid and ordinary fluids?
best regards |
February 26, 2019, 07:03 |
HD
Thermal Properties, Size of nanoparticles, physical properties
February 26, 2019, 21:10 |
Alexander
Rep Power: 34 |
So you know what you are looking for
you may find information about controlling material properties using UDF here: Ansys Fluent Customization manual you may start with DEFINE_PROPERTY macro best regards |
nanofluid, udf |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 12:43 |
UDF for inlet velocity alongwith UDF for properties | akshayy224 | FLUENT | 0 | February 1, 2018 09:17 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
