UDF to simulate liquid with certain frequecy vibration |
April 6, 2019, 01:25 |
samm
Rep Power: 7 |
I need UDF to simulate liquid in container, having liquid at bottom with certain frequency to create a droplet clouds. please share some ideas to build UDF. considered liquid is kerosene and I'm working In fluent. |
April 11, 2019, 12:17 |
samm
Rep Power: 7 |
anyone please...how to simulate a liquid with frequency value in fluent
April 12, 2019, 00:29 |
Alexander
Rep Power: 34 |
frequency of what?
best regards |
April 12, 2019, 02:04 |
samm
Rep Power: 7 |
Thank you for your response,
Frequency of ultrasonic transducer, Its an experimental work,where kerosene at bottom of the chamber and with the help of ultrasonic transducer it provide 24MHz to simulate that liquid ,by that it forms droplet clouds. Now I dont know how to approach that same thing in fluent.. please help me. Thanks |
April 13, 2019, 04:10 |
samm
Rep Power: 7 |
I found some equation... anyone please help me how to write udf for this
Pu = Pa cos {w(t+ z/c)} where Pa = root 2I row c I= Pus / A Pa- amplitude of sound pressure w(omega)- 2 pi f angular freq t time z space coordinates c sound speed in water f frequency I sound intensity Pus ultrasonic power A ultrasonic transducer area. please help me with this |
April 18, 2019, 05:38 |
samm
Rep Power: 7 |
Anyone pls... im stuck here.. hope someone will help me with this.
April 18, 2019, 20:37 |
Alexander
Rep Power: 34 |
the problem is how are you going to simulate this, are you going to use DPM?
equations and UDF is not a problem I suggest you to move this thread to FLUENT branch (not Fluent UDF) best regards |
April 18, 2019, 23:32 |
samm
Rep Power: 7 |
Thank you so much for your response..
yes im going to use DPM... after that how can I approach..? ill move this thread as per your advice. Thanks, Jegan. |
frequency, kerosene, udf, ultrasonic transducer |
problem in temperature and liquid fraction value in the udf | durg | FLUENT | 0 | October 23, 2018 01:52 |
Error when trying to simulate with a DEFINE_SOURCE UDF | PapaJoz | FLUENT | 1 | May 10, 2017 06:37 |
how to use UDF to obtain the thred of the interface between the liquid and the wall? | hellowqy | Fluent UDF and Scheme Programming | 8 | December 17, 2015 10:03 |
How to simulate the process of water evaporation by UDF? | qiyang860908 | Fluent UDF and Scheme Programming | 10 | January 9, 2015 13:59 |
can VOF simulate 3 phase fluid?should i use UDF?? | sincity | FLUENT | 0 | July 18, 2011 07:53 |
