Trap condition UDF
Old   April 21, 2019, 18:57
Default Trap condition UDF
FlavioC is on a distinguished road
Hello to everyone, I am working in a particle trap condition when particles satisfies that 0.001>vrel, where vrel is the fluid velocity minus the particle velocity. This is my code:
#include "udf.h"
DEFINE_DPM_BC(best_dpmbc3,p,t,f,f_normal,dim)
    /*Variable declarations*/
    int i;  /*working counter for script*/
    real vrel;
    real rx, ry, rz;
    /*Variable evaluations*/
    cell_t c;
    c=P_CELL(p);
    rx=C_U(c,t)-P_VEL(p)[0];
    ry=C_V(c,t)-P_VEL(p)[1];
    rz=C_W(c,t)-P_VEL(p)[2];
    vrel = sqrt(rx*rx+ry*ry+rz*rz);
        if(0.001 > vrel)
        for(i=0; i<dim; i++)
        P_VEL(p)[i] = 0;
        return PATH_ABORT;
    /*Stop tracking the particle*/
    else
	return PATH_ACTIVE;
It can be compiled without any problema but when I select this udf in the boundary condition panel , fluent gave me this message:
Error: received a fatal signal (Segmentation fault).Error Object: #f
I am novice in the UDF area, can someone give me suggestions or opinions please?
FlavioC is offline   Reply With Quote
Old   April 21, 2019, 21:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you are using C_U(c,t) macro but c has nothing inside
you should make loop over cell/threads to use C_U(c,t)
thread_loop_c(t,domain)
begin_c_loop(c,t)
code
end_c_loop(c,t)
best regards
AlexanderZ is offline   Reply With Quote
Old   April 22, 2019, 13:10
Default relative velocity
Hello AlexanderZ.
Thanks for you replay. I really appreciate your answer. Could you please give me some help on the uses of loop macro, I have been reading about it, but all my attempts have failed.
Old   April 22, 2019, 20:41
Alexander
I've already gave you a tip.
More information in Ansys Fluent Customization manual
best regards
Old   April 23, 2019, 22:32
Thanks for you help. I will try.
Old   April 24, 2019, 01:09
Alexander
I was wrong there.
I your code c and thread were defined so you don't need a loop.
I have no experience with DPM but it seems like DEFINE_DPM_BC macro is defined on boundary (face) only, so any data related to cells is not avaliable.
You may try to get the data from cell,which is adjusted to this face using
c0 = F_C0(f,t);
t0 = THREAD_T0(t);
however, I/m not sure how it will work
on the other hand, in UDF manual there is some macro WALL_F_VV(f,thread)[i]
there is no information how it works.
You may try to find something in Ansys Fluent Customization manual in DEFINE_DPM_BC chapter
best regards
condition, segmentation fault, trap, udf
UDF setting wall boundary condition with a DEFINE_PROFILE NLao FLUENT 3 September 2, 2019 00:33
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 21:55
UDF for 3rd Kind Boundary Condition Ismail FLUENT 2 October 26, 2015 01:57
udf for dpm boundary condition ucmaen Fluent UDF and Scheme Programming 0 July 15, 2014 13:33
UDF for traction-free boundary condition at outlet psb Fluent UDF and Scheme Programming 0 November 10, 2009 02:40
